Question about RCA HD52W59 HDTV Projection Television
Convergence issue what if the convergence options are there put none of them actually do anything?  it is a rca hd52w63d
  • schnuck Dec 06, 2008
    When I select autoconvergence, the screen flashes black and then a green image flashes on each side of the screen. Then it just goes back to the menu screen with no changes.
    The picture itself (on live tv or in the menus) is bowed in on the top and bottom, with the three colors not alligned properly(it looks like I should be wearing 3D glasses.)
    I have also tried the manual convergence with no luck.  Neither manual convergence test will allow me to move the crosshair...at all.
    With that being said, what would you say is my issue?
    Genius:
  • 1,030 Answers
Convergence in the itc222 chasis is controled by three cuircit boards. when you select convegence option first try autoconvergence watch what happens closely. does your picture apeard bowed> if so then you more that likely have a convergence power board issue. IF you try manual convegence of the red or blue and if they move dont move eather left or right up or down then likely it will be the convergence amplifer board. Now if all that fails then there one more possibility the ssb or small signal board this board has the convergence processor on it. if this board is faulty then it willl take a tech with special equipment to replace
Posted on Dec 06, 2008
Convergence option dropped from menu on rca tv
thats a very easy repair if you can solder Replace FL231, DL231 and CL230 then resolder the flyback that will solve the issue. You can get the Kit called ITC222 and ITC222a Convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with repair instructions.
Jan 01, 2012 | RCA HD52W56 52" Rear Projection HDTV
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Where are the convergence chips and resistors (pico fuses) located in the rca hd52w59 hdtv projection tv?
There are none in that chassis. You can get the convergence option missing repair kit at the following link and the kit contains the parts and CD with instructions. www.tvrepairworld.com
Sep 12, 2009 | RCA HD52W59 HDTV Projection Television
I see the convergence option in menu but nothing changed
Since you have the convergence options in your menu i would figure that you do not have the common fl231 fuse problem....Now is any part of the picture good. is the picture a bow tie. if you go into red and blue manual option will the crosshairs move up and down and left and right. If you have the bowtie or push in fromtop and bottoml then the likely problem is what is call the convergence power board. if you do have some control over the crosshairs then it may be the convergence amp board. convergence is controled by three diffrent cuicit boards. if you have to replace these boards it may just may need someone like a tech to do a serivce convergence.
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W66 convergence problem
you will need to replace FL231, DL231 and CL230 all located on the deflection board . You can get replacements at the following link with free instructions on how to do the repair. the parts are all listed under the RCA parts category. Heres the link http://servicemanuals.vstore.ca/
Jan 06, 2009 | RCA HD52W66 Projection Television
CONVERGENCE ISSUE *UPDATED* RCA HD52W63D
Convergence Power supply board. In the television above the cuircit boards there are two curcit boards that sort of hang above. the one on the right is the convergence amplifer board(has metal fin like heat sinks).. The one on the left is the convergence power board. Since you have options and no control, bowing picture. this would be my first choice. Now it still may have convergence amplier trouble. To get these boards you will have to get the entire model with suffix ext. it will be like d52w20...yx1 yx2 or something like that. in small leter on the model sticker on back
l
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Big Screen problem
What did you put in. convergence amp or convergence power. this is a rca hd52w59? i always ask the question in customer menu under setup can you see the option of convergence. if not this is the fl231 fuse problem. consult the article fl231 under tips and tricks section of my profile. the curved picture is an indication complete loss of convergence power. there is a board that does provide convergece power. The convergence on this set is controled by three diffrent boards. power,amp and the small signal board. the small signal board is the most expensive and most complicated to replace ussally a tech has to replace that.
Nov 08, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w67 w/irc222 chassis
if in setup the convergence option is missing then more than likely a special fuse fl231 has blown... this is caused by bad solder connections on the part known as the flyback... if you can solder and get the fuse then this could be a simple fix
Jun 01, 2008 | RCA HD52W59 HDTV Projection Television
Rca d52w23
if u press menu on remote control and scroll down to set up , press ok and see convergance as an option choose it and adjust convergance.(lines up your colors) if u do this and convergance does not even show on your menu at all anywhere! like mine, then u have an open fuse for convergance board. mine is going to shop for this today.
Sep 17, 2007 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
