Question about Acer AL1703 17" LCD Monitor
Display looks like a negative photo
I have no colors in my screen execpt negative
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
Feb 11, 2016 | Vizio VO370M LCD TV
When turned on everything looks like a negative photo, help
I don't know what device you have.
Settings > scroll down to System > Accessibility> uncheck 'Negative colors'
If there is such option. If not, your screen panel may be broken or some connection inside the device has come loose.
Jun 07, 2015 | Tablets & eReaders
Display Colors
use the paid for it...
Feb 02, 2014 | Proscan 7-Inch Android Internet Tablet,...
On the startup screen color negative
Hi, It's an unusual problem but I don't thinks it's hardware. Most likely a corrupted preference file. Remember the screen just displays what is sent to it. if the signal arriveing is reversed then you get what you are experiencing.Go to your Home Folder (the one with the house icon) and loctate the Library Folder. In there locate the preferences folder and look for
Locate it and put it in the trash.
make sure you have the screen showing the correct way around and then shut the computer down.
Restart and see what happens. If it's still the same, do the routine again but this time leave the screen in negative mode before shutting down.
Post back and let us know what happens.
Jan 28, 2013 | Apple MacBook Pro with 17" Display
What is causing my TV to display inverted colors, like a negative photograph? The picture of my LN46A530 LCD TV has degraded an it looks like if I was seeing a negative photo.
TV display inverted colors, like a negative photograph because defective panel. Mostly from T-con board. Replace T-con board.
I hope that will solve your problem.
Mar 03, 2011 | Samsung LN46A530 46 in. LCD HDTV
My MacBook Pro display screen is looking very a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
My screen looks like a photo negative..I have a Toshiba Satellite.
Right click on your Desktop, click on Properties, then go to the Settings tab and set the color to 32 bit True Color.
It sounds to me like your display settings are set to monochrome/black and white.
Best Regards,
Jul 21, 2009 | Computers & Internet
My printer worked fine when I used it a month or two ago to print color photos. Now it is printing them in negative for no reason. Even when I do a preview before printing the preview shows the photo in...
When you are on the print window at the end of the process, look for a "Preferences" or "Options", then look for tabs or other menus that say "Color" or some sort of "output" mode and see if there is a negative option you can disable.
Apr 16, 2009 | Canon Pixma iP4500 InkJet Printer
HP Pavilion DV7 Display problem
How long have the colors on your display been "reversed/inverted" and looking like a negative....... Did you drop or damage the laptop in any way (sudden shock/bump)? Also, has it been allowed to overheat (if you run the laptop while it is sitting on a soft surface such as a bed, pillow, couch, etc it can allow the motherboard to overheat because it cannot get the airflow through the cooling system through the fan/vents because they are blocked). Have you checked to see if your laptop is included in the "HP Service Enhancement" program???
Mar 01, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Acer AL1703 17" LCD Monitor Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
