Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Replacing the blue filter on the Zenith rear projection LCD TV.
Thank you, you've provided the only do-it-yourself advice on how to fix the yellow circle in the middle of my screen without paying a technician as much as it would cost to buy a new one.  If you don't mind I have a few additional questions.  Do you have any suggestions of where I can a blue replacement filter?  And more specifically what I should be asking/looking for?
Many Thanks!
3 Suggested Answers
johnnydiode
  • 647 Answers
SOURCE: Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Posted on Sep 22, 2009
SOURCE: blue spot on tv screen
Better yet watch it till it completely dies and then pitch it! It costs more to replace the light engine than it would to buy a new tv....I will be putting on in the layaway soon!
Posted on Apr 03, 2010
My zenith lcd tv has lost its blue tint. most
the light polarizer on the blue lcd panel is fried due to excesive dust and heat, and therefore need to be replaced. unfortunately, zenith may not sell individual parts of the optical engine, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
Replacement Filter for LCD TV
hey there yeah you are right your LCD is brunt out, to be honest with you I don't think they sale just the LCD chips you have to buy the OPTICAL BLOCK to fix this problem good luck.
Dec 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze
If your model number is E44W46LCD Rear Projection , yes this will should fix your problem and you can do it yourself. Just be careful with the LCD cube that is beside you color filters, it is very fragile and hard to get.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Yellow haze
Hi...the yellow haze is probably the blue filter is burnt and needs replaced. This is very common in Zeniths. There are 3 color filters in the Zeniths blue (pinkish in color), green (grayish in color) and the red (it is red). The #1 problem in this TV is the blue filter is burnt and it is an easy fix. It could also be the LCD cube is bad. I would try the blue filter replacement first. It will probably do the trick.
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Growing blue haze on our picture screen.
This is a bad problem with the light engine caused by overheating usually due to reduced airflow from dirty air filters.
My recommendation is to push your warranty company to replace this subpar model with a different one. There are too many instances of repaired models having a reoccurance of this same problem.
The blue line you are seeing is a product of one or two possibilities. The LCD panel which provides the blue imagery, which by the way is made by SONY Electronics, is defective. The LCD panel, in the optic engine (made by Ricoh) is basically loosing partial horizontal data, or the blue color filter has overheated and is becoming discolored, causing the loss of correct deflection through the optic prism. There are two ways to approach this. LG can offer some concessions and get you squared away, or provide the part, and you would be responsible for the service labor involved. Either way it can happen. The first thing I have to suggest to anyone purchasing a LCD or DLP projection TV is REMEMBER to keep an eye on the air intake filters. LG / Zenith products have one in the rear of the set, and 1 on the bottom of the unit. Reduced air flow through these units cause these "video deflection" issues. Overheating plainly affects these sets. I personally wouldn't own one, no matter who made it.
Jan 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith lcd with a yellow dot
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
Dec 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
