Mitsubishi TV guide does not function - TV model CS-36509
When I set up, it goes through stations ( only up to 99 out of 125).  I turn TV off per instruction, I wait for 30 minutes per instructions.  When I turn TV back on, its on only channel 99 (fuzzy), but the yellow message on the bottom of the screen is not there.  I press the TV guide button but nothing happens.  TV guide plus has not been installed.  I suspect it does not complete the set up.  I have unplugged & replugged the system, and turn the TV on numerous times.  Then the yellow message is then on the bottom of the screen setting the channels.  I turn the TV off, wait 1/2 hr, turn the TV back on to again find it only, on fuzzy channel 99.  The TV is appx 10 yrs old and the TV guide plus has always functioned.  It has lost the TV guide plus at times, but I have reinstalled it easily.  I have had this problem only for 2 wks.  Can you help me?
  • 4 Answers
SOURCE: how do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
Benimur
  • 6966 Answers
SOURCE: I have just purchased A
Hi ttemmeg,
With the indulgence of s4u311...
Based on your post and subsequent comment, I am tempted to assume that your SC-RT 30 is somehow locked. You may need to do a full hard reset which is done by simply unplugging the unit from the mains for a couple of hours (overnight preferably). Thereafter pls try and you may have to do the initial set-up again.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: Cannot set channels
It is the software or the program that have the TV to operate properly.  Sorry for my english.
Posted on Jan 27, 2009
SOURCE: TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Posted on Mar 04, 2009
SOURCE: MGA 1989 19inch standard tv. - model #CS-1946R
Try this. I the control box under screen (with a door) is a botton TV/CABLE.HCR. Try pressing this button to get more channels. Mine was on TV, but needed CABLE. Best wishes.
Posted on May 30, 2009
What type of TV (rp, crt, HD etc) is the Mitsubishi CS-36509
This TV is a CRT type and is not an HD because it was manufactured way before the HD signals became available.
Sep 01, 2015 | Mitsubishi Televison & Video
How to reboot my Mitsubishi Cs-36509
the tv reset .soo your going to need the remote that came with the tv to get to the menu.
May 10, 2015 | Mitsubishi Televison & Video
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
Guide plus issue
bestbuy has universial tv remotes.
Mar 21, 2012 | Mitsubishi CS-36509 TV
I am trying to find the user manual (not repair) for a Mitsubishi cs-36509 TV. Thank you for your help. Peter de Pippo
Try here it takes a while to load
http://www.managemylife.com/mmh/owner_manuals/572/MITSUBISHI-Direct-View-Digital-27%22-to-40%22-TV-97110161
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Mitsubishi CS-36509 TV
How much does a mitsubishi cs-36509 weigh
it depends if its a dlp it is medium not so much heavy if its lcd its also medium if its c.r.t. it is heavy if its projection its is reallly heavy if theres is misunderstandings of what i just said contact me by 2105334824 ask for benjamin sanchez or email me sanchez7808@hotmail.com
Feb 07, 2011 | Mitsubishi CS-36509 TV
Where/how can I get a owners manual for the Mitsubishi 36" TV (Model# CS-36509)?
what is it or what info are you looking for this set is an older mitsubishi older chassis -Zm chassis and is the same set as the mitsubishi modelCS_4053 there are no boards available for theses sets any longer, Sorry Man
Techman
May 18, 2010 | Televison & Video
Cs-36509 mitsubishi tv has a flicker.Makes it hard to read words. Is real bad when you first turn the tv on, but after a minute it settles down, but is still there all the time... any suggestions?
Yes first it may just be bad solder on the
flyback transformer , or the Picture in Picture
module has some bad caps . a fair shop
price is about 180-200 and it worth the repair
they are great TVs and are made to last.
ps i have repaired my mitsubishi once , and
its going strong. 18 years old .
THE OLD STUFF IS BETTER THEN THE NEW STUFF.
Mar 25, 2009 | Mitsubishi CS-36509 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Electro Med Services...
