Question about Motorola Mobility MPx200
Phone wont charge
Bought a new battery for my phone thought that was my problem. Now I can't get the new one to charge shows nothing when connected to charger. Any ideas??
0 characters
1 Points
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
Apr 13, 2010 | Samsung Blackjack SGH-I607 Smartphone
T-Mobile MDA Phone wont now charge or turn on
Mar 06, 2010 | T-Mobile MDA
My dell axim does not charge a new battery- I tried 2 new ones.
check the charging unit or the plug on ure phone,it mite be loose and not charging
Sep 24, 2009 | Dell Axim X50 Pocket PC
Basically my fone wont switch on and even wen iv charged it it still shows the low battery charging symbol but wont switch on!! iv bought a new battery and a new charger but it still doesnt work!! and iv...
do what im about to do and throw it in the bin... these phones are pathetic and LG wont take responsibility for their crappy workmanship... all u get form the technical support is "what was the exact date u purchased it" even if u tell them its like a month out of warrenty...
Jun 16, 2009 | LG KU990 Viewty
Battery shows fully charged, stays on for 3 minutes and freezes.
I've had this happen. Try a soft reset, if that doesn't fix it - try a hard reset. If it still does this, you will need to replace the battery. It may either be a problem with the battery itself or the power regulation circuit that is built into the battery. Either way, replace the battery and it should fix it. Word of warning though, some aftermarket chargers actually reverse-charge the battery - I had a USB charge/data cradle that did this and I still have short-lived battery life on my new E2 battery if I use that cradle. I just stopped using it because it kills my E2.
Jan 12, 2009 | HTC Touch P3450 Smartphone
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
Jul 22, 2008 | RIM BlackBerry 7100t
Blackjack cell phone AT&T won't charge or turn on
Go back to AT&T, or find somebody else who has a Blackjack II and put thier battery in the phone to see if this 'jump starts' it. I have had the same problem now 3 times. There seems to be a consistent issue with Blackjacks just not charging after a while, then the battery runs down and you can't turn the phone on again. 1st time AT&T put a new battery in mine and it turned straight on! 3 weeks later it happend again and they gave me a new phone AND another new battery. 3 weeks later the same thing has happened again with thenew phone. Never seen this happen with any other phone model.
Jun 26, 2008 | Samsung BlackJack Smartphone
T mobile mda
mine also did it and finally nothing on even I thought battery died I bought a new one.
Jun 14, 2008 | T-Mobile MDA
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
Motorola Mobility MPx200 Logo
18 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
