Question about StarView SV211K 2-port KVM Switch
My clutch and flywheel are gone on my zafira 03 plate
The flywheel is a 2 piece (floating) i want to know if their is a kit available to change it to a one piece clutch assemble
    Problem Solver:
  • 5 Answers
There is a company in Northern Ireland called Exact Engineering that will courir-collect your malfunctioning floating flywheel, convert it to a single mass flywheel, and courir it back to you. They can also couirir you a fixed single mass Zafira fywheel if they have any in stock.
Their website is and you can email them on
Posted on May 29, 2009
My clutch on my 1985 Toyota truck has these problems the gears are hard to engage when truck warms up and now when I Release the clutch it moves less then a half an inch and the truck wants to take off can...
I suspect your clutch and pressure plate needs to be replaced,when you depress your pedal to disengage your transmission from your flywheel the pressure plate is not engaging enough to seperate the two it still has a little contact on your flywheel so it is going to be difficult to change gears and your relief is going to be shorter.If you change it out always remember buy a clutch kit with a clutch plate and pressure plate and pilot bushing and slave cylinder all in one kit.Always remove your flywheel and get it resurfaced that is a must ,the flywheels surface will become uneven over time and minimize your surface area on your disc,by getting it resurfaced it will assure your disc has 100% of the flywheel surface for hook up and when you depress your clutch it will clear your flywheel good luck
Jan 15, 2014 | Cars & Trucks
DYI Clutch change, now transmission won't fit with the new clutch kit??
While its seams you don't see where you have to make caution,
So Now !Put back fry-wheel back on crankshaft then just check two thinks ......Check 1: see clutch plate there is center gropes on it so Mach on gear shaft center gropes.(I mean just put clutch plate in to transmission shaft & check if it`s center gropes are same match) If yes then pull back clutch plat & then refit under pressure plate on fly-wheel. Now come to Check 2 ! Mow when you fit it you must do centering of clutch plat to fix on gear shaft, So How you can do ?
There is two ways 1 is you have same shaft designed road or wood piece which help to center it!
While 2 ways is take big screw driver & put in the hole & do centering by looking it where center come just tight pressure plat bolts to hold the center .
So when you did like this you ll fix transmission (gear box) easily in a mints ....Just simple like this.
So best of luck & if you have any problem just mail me
Nov 25, 2013 | Cars & Trucks
Clutch installation
Genewrally speaking you need to remove the gear box. UNdo the bolts holding the clutch pressure plate on the flywheel. . Do this by undoing each bolt a few turns at a time. Remove pressure plate and clutch plate. Clean flywheel face. Remove bearing at center of crankshaft and replace as it will be dry and probably rusty. Fit new clutch plate taking care to observe the correct way the plate is fitted. Normally the raised hub section faces away from the flywheel. THis can be checked by pressing the plate against the flywheel and turning it and it it hits the crank bolts you have it in the wrong way round. Fit the pressure plate over the plate and insert the bolts. Some units have 2 or 4 bolts longer than the restand this is to allow the plate to be depressed a fraction to allow the other bolts to screw in. Place a clutch aligning tool through the clutch plate and into the bearing. Evenly retension the pressure plate bolts going alternately across the cover a bit at a time . When retensioned remove the clutch aligning tool. Remove and replace the throw out bearing on the clutch release forks. Ensure that the clutch kit is all new as mixing parts will not work. Refit the gear box. Basically that is the proceedure but to be exact get the manual for your vehicle to cover any extra steps needed for that vehicle.
Mar 07, 2013 | Ford Transit Connect Cars & Trucks
Explorer 4WD manual 2000 stiff gear change
Are you sure you installed clutch plate facing right way? They are either stamped or have a tag says "flywheel side". Or might have wrong clutch kit.
Jun 26, 2012 | 2000 Ford Explorer
I am fitting a new clutch assy to my vy ss ute, i bought the kit genuine from Holden removed the old assy and fitted the new flywheel,clutch plate n pressure plate. but my problem is that i have torqued...
did you use a pilot spline to align the clutch and did you change the pilot bearing in the end of the crank. The clutch plate maybe interfering with the pressure plate if it is not lined up.
May 06, 2017 | Cars & Trucks
I'm about to purchase a 1989 VW Cabriolet. During a test drive while going up a small hill, the clutch slipped. It didn't seem to happen the rest of the drive. I'm not sure exactly what it is called but...
If the clutch is actually worn, you'll need to pull the transmission and change the clutch disc, pressure plate, and throwout bearing. They don't normally all need to be changed, but the kits usually contain all the parts, and you won't want to pull the transmission to replace the part you didn't swap while you were in there already. (or pay someone else to, for that matter...)
On a 1989, the clutch linkage is cable operated, not hydraulic. Check first to see how much you can lift up the arm that the cable attaches to. You should only be able to lift it approx 1/2" or so away from the cable by applying only one fingers' worth of pressure from underneath the bar. If you can move it any further than that, adjust the cable so that you cannot, and drive again.
However, if the pedal feel is "at the top", as you say, it's probably adjusted properly as is, and the clutch will truly need to be replaced.
Also check to see that there is no oil seeping from between the block and transmission... if there is, the engine is leaking from either the oil pan seal, or rear main seal, or the transmission is leaking from the input bearing seal. Any of those will cause a clutch to slip, should the oil contaminate the clutch face.
A new clutch shouldn't cost more than $150, and having a shop install it shouldn't cost more than about 4 hours labor, plus any applicable fees. You should also change the fluid in the transmission and all fluids in the car while you're in there.
Jul 22, 2010 | 1989 Volkswagen Cabriolet
We have installed a new clutch kit, flywheel, master cylinder,slave cylinder and a few other random parts in my son's 03 Tiburon, yet the clutch simply will not engage. Any ideas on how to fix this, the...
Well it sounds like you have done the right thing like replacing the lot not just a centre platr BUTwhat you have done by the sound of it if you push in the clutch and the g/box just grinds and wont look like going in then your problem is that you have the CENTRE plate around the wroug way as the part with the springs etc have to go into the pressure plate housing ASyou have it its jamed up on the bolts on the Flywheel
TAKE it off change it around and away you go But make sure you have bleed the clutch and it should drive 1" off the floor and if so then you have done a good job...Let me know how you go Ron
Are you on Skype??
Oct 13, 2009 | 2003 Hyundai Tiburon
1999 2.0L TD Suzuki vitara the clutch pedal was low and grumpy when pressed and hard to select 1st or reverse. plenty of movement in clutch slave arm and no fluid leaks to be i removed the gearbox...
Pilot bearing (pressed into flywheel) or release bearing (presses against clutch pressure plate)?
Regardless, the repair is the same. Replace clutch disc, pressure plate, release bearing & pilot bearing. Most flywheels are available or as part of a complete kit, minimum is to inspect & resurface flywheel when replacing clutch assymbly.
Feb 17, 2009 | 1999 Suzuki Vitara
I have and 03 Toyota hilux turbo deisel and there seems to be a whistling noise coming from the gear box, but if I rest my foot on the clutch it goes away. Would you know what this might be?? Regards...
Sound like the diaphragm springs on the pressure plate. are being worn by the release bearing. The release bearing seizes up and causes a whistling sound when parked, with out clutch depressed. You will eventually. lose you clutch if you let this persist. The best thing you can do is replace the clutch pressure, clutch, reliese bearing, and pilot bearing. All this comes with a clutch kit.
I also recomend resurfacing your flywheel.
-to remove your pilot bearing you can fill the hole with grease and take a 3/8 extention and hit the extention into hole. this usual allows the pilot bearing to come out.
I bet your pressure plate will look like this
Aug 31, 2008 | Toyota Tacoma Cars & Trucks
Not finding what you are looking for? StarView SV211K 2-port KVM Switch Logo
286 people viewed this question
Alun Cox
