I have a x1270 all in one printer i have put in a new black cartridge and done the alignment to where i can see the darkest arrows and still can't get anywhere before i put in new cartridge worked fine
There should have been a softwaer Cd privided when U purchased the printer or if not then you need to download it from the Lexmark Website and make sure it is for your model of printer.
Try this link: http://downloads.lexmark.com/perl/downloads/downloads.cgi
IT MIGHT BE THAT THE BLACK INK RAN OUT OF INK SO ITS NOT PRINTING IN BLACK.However try changing the ink cartridge... If you have already done so then remove the ink cartridge and the clean the copper contacts with a lint free cloth... then shake the ink cartridge and then put it back in. then check if it works... if it does not then remove the power chord from the back of the printer without turning off the printer... then press and hold the power button for 30 sec...
then release the power button and then plug in the power chord...
again try printing in black.. if it does not then follow the steps below..
press the setup icon on the printer >> go to tools >> Clean Printhead ...
after it is done again go to setup >> tools >>Align Printer
after it is done check if black prints or not..
if not then Press BL/TL/BL/BL Buttons, in sequence (BL- Bottom Left, TL: Top Left) >>Touch Support Menu>>
Press Right arrow for Reset Menu and Touch OK >>
Press Right arrow for Semiful Reset and Touch OK >>
Wait for unit to Power Down/Turn Off>>
Press Power button to turn the Printer On.
Check if it works or not... if it does not then service the product
Take out the power cable from the back of the printer. Press and hold the ok and Cancel button together , while plugging in the power cable. It will ask you to alighn the cartridges- Do it and that will fix your issue.
Turn on the printer (the cartridges will not move without power to the printer) and open the front access door on the front right of the unit. Wait until the cartridge carrier comes to a full stop (idle and silent) in this opening. Press down lightly on the cartridge to be changed and then pull the cartridge out of the slot towards you.
Remove the new cartridge from the packaging and remove the tape that protects the contacts. Hold the cartridge by the black plastic; do not touch the electrical contacts or the nozzles. Hold the cartridge with the HP logo up on top and slide the cartridge into the slot until it snaps into place. (Color on the left and black on the right) When done changing the cartridges (if you need to do both), close the access door and wait for the unit to print an alignment page. Then scan the alignment page. If the alignment page doesn't print on its own. Press the Setup button (looks like a wrench) on the printer. Select Tools (left/right arrows) and press OK. Then select Align Cartridges and press OK. Put the alignment page face down on the glass so that the text is to the right of the unit. Then press OK.
Your printer uses 4 cartridges: PGI-5 Black and CLI-8 (Cyan/Magenta/Yellow). Unless you have a slot for a fifth cartridge, CLI-8BK cannot be used in your printer.
As for installing new cartridges:
Turn your printer on.Open the printer's lid. The printer
will automatically move the ink cartridges to the center of the opening.
Unplug the printer's power supply cord from the electrical
outlet to avoid the risk of an electrical shock.
Remove the printer cartridges by first pressing down on the
top of each cartridge housing. Pressing down on the cartridge housings
will cause the top of each housing to automatically lift up, thereby
exposing the cartridges. Lift the cartridges out of each cartridge
housing to remove them.
Install the replacement ink cartridges by first removing the
orange safety tape located on either the top or the bottom of each
cartridge, depending on the particular type of cartridge. The safety
tape ensures that the cartridges do not leak ink before being installed.
To remove the tape, simply pull the orange tab on the end of each piece
of tape away from each cartridge. Position each cartridge into its
cartridge housing so that the printed words on top of the each cartridge
faces towards the front of the printer, then close the tops of the
cartridge housings.
Plug the printer's power cord into an electrical outlet, then
close the access panel by pressing down on the panel.
Turn the printer on and allow the printer a few minutes to
recognize the new cartridges, then insert at least three pieces of paper
into the paper tray, which the printer will require to align the
cartridges.
Align the new cartridges by selecting either the "Clean and
Align" or the "Cartridge Alignment" option, depending on the particular
printer model. Some Canon models require the user to align the
cartridges through the printer's software program. Select the "Print
Properties" option in the printer's program, then select the "Clean and
Align" option. The printer will produce several printed pages to confirm
that the cartridges have been aligned. Other Canon models allow the
user to align the cartridges directly from the printer. These printers
features a display screen on the printer. Press the "Menu" button on the
display, then use the arrow keys to select "Settings." Press the "OK"
button, then use the arrow keys to highlight "Maintenance." Press the
"OK" button, then use the arrow keys to highlight "Manual Head Align."
Press the "OK" button, then use the arrow keys to highlight "Yes." Press
the "OK" button one final time, then allow the printer to produce the
printed pages confirming that the cartridges have been aligned.
The paper is jaming or not going through the printer evenly.Open it up and look for anything loose or broken like teeth on wheels or somethng sticky or even paper dust. Then try one piece of paper alone first.
his maybe stupid but what calibration tool all i see is about
alighnment tell me where and what to do and i will check it out thanks
Have you run the lexmark claibration tool ?
or any other Lexmark tools ?
