Question about Stoves Kitchen Ranges
Would anybody know where the fuses are on old stoves? I have an old stove, which I am renting with my apartment. There is no brand name on it but since it is olive-green, it must go back to the 70s, if not the 60s. I believe that a fuse blew up because both elements on the right side stopped working at the same time (it sounded like a gunfire.). There is no heat and no light on either one. I know that on modern stoves, the fuses are on top and easily accessible but on this one, I cannot find them. I opened the top (which is screwed) and saw nothing. I would appreciate your help.
  • 706 Answers
Hello Lucie,
If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. I would highly recommend that you remove or disable power to the stove prior to making any component changes...
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
I would think that your landlord ( since you are renting) would be responsible for the maintence and/or replacement of your stove,,,
Good Luck..
Regards,
Rick
Posted on Dec 04, 2008
Why surface control knobs become hot when oven is on
If its an older model gas stove, then its normal. I have an older gas stove and the knobs get a little hot when the oven is on. Nothing that prevents me from using it, but enough to notice they are warm.
If its a newer stove, you should contact the manufacturer. Without knowing more info, I can only give a general answer.
If you're renting in an apartment then talk to the management or maintenance. If you're leasing the stove, call the company its being leased from.
Sep 30, 2015 | Kitchen Ranges
I( am looking for a wiring diagram for a stove
Bernard,
Can you give us more information like the brand name and model?
Jul 01, 2015 | Stoves Kitchen Ranges
How do i heat up stove??
all stoves come with fuses in the stove its self usually under the lid above the knob areaand in the fuse box of your house or apartment building check that out first if thats not it an electrican is in order
Dec 25, 2011 | Kitchen Ranges
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
Hi! My old school Admiral oven/stove top is having issues. I rent, so I don't want to bother my landlord until I have to - or know what to tell him. Basically, it won't heat anything substantially. The...
You need to contact the landlord and I will tell you why: The stove should not have issues above and below simultaneously. I comment you for not wanting to bother the landlord but I feel like you have an electrical problem. The oven not there and the top not there? You have a bad circuit breaker on that puppy. Takes a 50 amp 2 pole 240 volt breaker for an electric stove and only qualified schocktricians should fool with them. My opinion.
Nov 30, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
How do I clean stainless steel stove?
Send me an email and I can direct you to what we use and sell, help@timerking.com.
Hope this helps!
Nov 04, 2009 | Cooktops
I have an old stove and the oven will not heat i
Temp.control..gone ..sensor bulb..
Aug 18, 2009 | Kitchen Ranges
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
Replacing a glass cook top
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Jan 09, 2008 | Ovens
Kitchen Ranges Logo
303 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
