Question about Lexmark JetPrinter X1185 All-In-One InkJet
I have a lexmark 1200 series all in one the text is good on some lines and overlaps on others or is missing i put in a new cartridge of black and did alighnment and got the page of arrows but still i can't seem to get it right its X1270
  • 2,692 Answers
The paper is jaming or not going through the printer evenly.Open it up and look for anything loose or broken like teeth on wheels or somethng sticky or even paper dust.  Then try one piece of paper alone first.
Posted on Dec 29, 2008
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X1290. I have been using the black cartridge....its still got ink in it and I am getting a Cartridge Missing Error. I have cleaned the cartridge and still no luck. What else can I do to fix the...
Try to clean the cartridge nozzles using the Lexmark Solution Center on your computer. Launch the application from All Programs > Lexmark 1200 Series Printer > Tools > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal lines. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Once done, try to print again and check if black is printing properly now. If that doesn't help, try to insert a different known working black cartridge to determine if the other is fautly.
Jun 15, 2011 | Lexmark X5150 All-In-One InkJet Printer
Lexmark Z615 inkjet printer - whetther I print in colour or black and white, I am getting whole lines of text/image missing. When I use the "clean nozzle" function some of the colours - like...
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
Jan 30, 2011 | Lexmark Z615 InkJet Printer
Each line of text is printing multiple times, lines overlap, and printing
Hello. That's an alignment problem in the printer. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. But, if it's possible, try to use new cartridges. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. Let it print an alignment page all the way through.
Mar 25, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error #1200
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
if that doesnt help...
remove the shell from the black base, clean the goop from under the ink cartridges, put silicon on the bars after cleaning with alcohol, grease the gears sparingly, put it back together,
good luck
Jul 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Missing stickeron cartridge
The Lexmark 2300 series should take the following cartridges:
Lexmark 12A1970 (Black)
Lexmark 12A1980 (Color)
Let me know if that helps!
Mar 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Poor printing
Gain new cartridges, possible that application time ended in yours.
Try to clean nozzles of cartridges by humid (wet) fabrics
Mar 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 1200 series printer won't print
Call me and I can walk you through what Lexmark just walked me through with the same problem
Jan 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
If you need to reinstall the software, uninstall it, then go to and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
If all the above fail to make it work, it is hosed, shop for new printer.
Dec 09, 2008 | Lexmark Office Equipment & Supplies
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
