Question about Epson GT 7000 Flatbed Scanner
How can I get my epson GT 700 scanner to work on windows XP
I was recently given the GT 7000, but was told it only works on windows 95/98, how can I get it to work on windows XP as it seems a great scanner and it's shame to get rid of it if I can get it to work on XP
    New Friend:
You cannot. A drive for this machine serves up to Window 2000.
Posted on May 03, 2013
I already purchase an epson scanner gt7000 fpr win 95/98, but need to install on winxp. but could not be installed
Posted on Dec 12, 2009
  • 75 Answers
Once it is installed on Windows XP you can change the setting in properties to run Windows 98 compatible. It used to work with older scanners and printers. Try it out.
Posted on Dec 04, 2008
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    I m loking for a driver for microsoft lifecam vx 700 to work on w2000 with sp4. thanks for answer.
    Are you sure it's a VX 700 rather than a VX 7000? The VX 7000 is not compatible with Windows 2000 unfortunately. Try the driver for XP.
    Feb 19, 2011 | Computers & Internet
    Hello, my name is Dino palamenghi and I have an Epson Scanner GT 7000. Should I have the driver to instll it on windows 7? Thanks in advance. Sincerely yours, Dino Palamenghi
    You should have the driver for this in Windows 7 by default if it works don't worry about it - if it doesn't work - look for it in driver and hardware - remove it and then reboot the pc. The pc will automatically find the printer sand seek out the Driver and install it.
    Get back to me for more information and will follow up with you for the next few days if need be.
    Gary @ Fix Ya
    Nov 30, 2010 | Epson GT 7000 Flatbed Scanner
    How do i install epson GT-7000 scanner software cd-rom without using disc drive
    Download the driver from onto a usb stick if needed. The appropriate driver as per your OS is available at
    http://driverscollection.com/?H=GT-7000&By=Epson
    Nov 16, 2010 | Epson GT 7000 Flatbed Scanner
    Looking for a driver for epson gt 7000 scanner for windows 7.thanks
    I do not see this scanner on the Epson support site. They may not have a Win7 driver. You could try an XP driver in the compatability mode (right click on the driver and select Properties and the Compatability tab. Check the box next to Run in compatability mode) You can download a driver from a site like this one, http://download.cnet.com/EPSON-GT-7000/3000-2118_4-73143.html .
    Another possibility is available in Win7 Pro and Ultimate. Download and install the XP mode from Microsoft. Install the scanner in the virtual XP computer. You may need to save files to external media to transfer them between the two computers.
    I hope this helps.
    Jan 31, 2010 | Epson GT 7000 Flatbed Scanner
    Can someone advise if the Epson GT-7000 scanner which I had working in XP can be made to work in Windows 7 or is it time to throw out my faithful machine? Rodney.
    I got mine working on Windows 7 (x64) by doing the following:
    1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site 2. Install the drivers 3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator 4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027 5. On line 51, 54, and 57 replace PID_011B with PID_0101 6. Save the file. 7. Connect and turn on the scanner. 8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software 9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked). 10. Say ok to the window that pops up and it should start installing the drivers.
    In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
    I hope that works for you :)
    Stephen
    Sep 28, 2009 | Epson GT 7000 Flatbed Scanner
    Epson GT 9000
    i have scanner epson GT9000(ES 1200C) and lost the driver to runnig it , I did fomat to my pc now my scanner not function pleas if you can help me to povide me the scanner driver.
    thanks
    May 31, 2008 | Epson GT 9000 Flatbed Scanner
    Epson GT5500 Flatbed scanner
    unfortunately Epson has not made a driver for this scanner that is compatible with Vista and from the looks of it, they don't seem to have any plans on making one!
    Sorry
    Jan 29, 2008 | Epson GT 5500 Flatbed Scanner
    Epson GT 7000 Flatbed Scanner Logo
    934 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
