Question about Canon PIXMA MP780 All-In-One InkJet Printer
How to print 3 3/4 x 6 3/4 sized paper
I would like to print some info on my "Filofax" diary which measures 3 3/4 x 6 3/4". Any solution will be appreciated with thanks. By the way, am using Canon Pixma MP780 TK
  • Ting Mong
    Ting Mong Feb 22, 2007
    Normally the printer prints A4 size paper, but I want to print a smaller sized paper measuring 3 3/4 x 6 3/4", what can I do/
I found the solution myself. 1. Open Canon MP Printer 2. Select "Printing Preference" 3. Click Page setup 4. Click "Custom" 5. Select "Portrait" 6. Select Normal size printing 7. Adjust Paper Holder to fit small sized paper
Posted on Mar 07, 2007
My Officejet 4500 does not eject a printed page fully, causing the next page to overprint the bottom of the previous page.
Sounds like the printer is set up to print a smaller size paper than the sheet size you are actually using. Measure your paper size, then go into the printer settings and choose the sheet size that matches.
Oct 20, 2014 | HP Officejet 4500 All-in-One Inkjet...
I want select size a5 in lct . mp 7500
Check the paper size in the machine settings. If not you might have to set it for custom size. Measure the paper to be printed and enter the size. You will probably have to put the paper in the manual feed/bypass tray.
Oct 11, 2013 | Ricoh MP 5500 7500 Photoconductor 889623
Help with printing to HP Design Jet 500ps from a PDF!
I have had some success by converting pdf to jpg and printing from Adobe Photoshop. The HP 500 ps and 500plus are VERY fussy about paper size conflicts.
Nov 22, 2017 | HP DesignJet 500ps (42 in.) InkJet Printer
When I want to make a copy it tells me "Paper size
Good day, Regarding the error message that your getting, that means the paper where you want to print that document is not supported by the printer. Usually you'll the see supported paper size if you click the print option or print setup for your printer. The only way to resolve this is to use the appropriate size of paper like.
You can also try this steps to change size for the documents you want to print
>Open the File menu and click Print.
>Click the Settings tab
>Click on Paper Size. A list of paper sizes will appear
>Select the size you want.
>If none of the selections are suitable, select Custom. A box will appear inviting you to set your
own measurements. Enter the width and length that you want.
>Click OK.
These are the usual paper size use. It's 8 1/2 by 11 inches and the other one that you could use in most printers is 8 1/2 by 14. The first one is known as Letter size, the other one is known as Legal size. Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | HP Photosmart 3310 Printer
Can I change the printer border on my Lexmark Pro901? In adobe when I go to print I find the actual page size is not the same size as the measured page size. The white area is smaller than the other...
Make sure the correct paper size is set in the print settings on your computer. Click the Properties button on any Windows print dialog. On Mac you can select paper size in the Print Settings pane in any expanded print dialog.
May 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Cannot adjust setting to print specific paper measurement
Your program should have a section in page setup to manage custom sizes. Enter this size. set size in your printer dialogue box and away you go! Inkypete
May 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
IBM 4234 dot matrix
Sounds like the configured paper sized does not match the actual paper page height. So that when it does Top Of Form paper movement the paper stops slightly too low. Doing several form feeds should confirm this. If this is it then reconfigure the paper size to match the paper. Also measure to paper to see if it matches what you want it to be.
Mar 04, 2008 | IBM 4232 Matrix Printer
Printer
hi galeinna,
I suggest you make sure that your printer is configured to print to the correct type of paper. I assume you are trying to print to A4 size paper.
If you are using Windows XP you can follow these steps to configure the printer:
1. Click Start -> Control Panel -> Printers and Faxes
2. Right-click on the 942 printer icon and click on Printer
preferences
3. Click on the Paper Setup tab and select the A4 type at
Paper Size.
If this doesn't fix the problem with the print output, I suggest you download the latest version of the 942's driver at
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A942&os=WW1&osl=en&catid=&impid=
and reinstall the printer using this driver.
Hope you find this info helpful in solving your printer's print output problem and thanks for using the FixYa service
Kind regards
Feb 15, 2008 | Dell 942 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
302 people viewed this question
old marine
old marine
