Question about Beverage-Air DW49 Stainless Steel Beverage Cooler Commercial
With the BevAir DW49 does a lower number mean colder or warmer?
The Bev Air DW49 has a control with readings from 1 to 6. Does 1 indicate the coldest setting and 6 the warmest, or vice versa?
    Scholar:
  • 81 Answers
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Posted on May 02, 2009
  • Beverage-Air Master
  • 1,238 Answers
In almost every case, turning the thermostat clockwise with be a colder setting. Most all Bev Air are like that. Turn know one number at a time and monitor the temps. You will be able to figure it out.
Posted on Jul 04, 2010
Adjust freezer temp
On my whirlpool refrigerator a higher number is colder. On the freezer section it is a-b-c with "a" being warmer and "c" being coldest.
Attached is a link to whirlpool manuals and troubleshooting. You will need the model number of your refrigerator or freezer.
Manuals and Troubleshooting Whirlpool
Jul 31, 2014 | Whirlpool Refrigerators
When turning up or down does that number mean the current room temperature or what you want it to be? And when doing that is the lower number mean cooler or warmer? And the number being displayed at all...
The number you can adjust is the temperature you want. A lower number is colder and a warmer number is hotter. Remember that even if you turn it up or down by a lot, it doesn't change the temperature any faster. The number you cannot adjust is the temperature at the thermostat.
Oct 17, 2017 | Heating & Cooling
Temperature control are the lower numbers colderr or warmer?
Hi there, the higher the number the colder the fridge, unless the numbers are in degrees. If it's numbered 1-6, 6 is the coldest. -Alex
Aug 17, 2011 | Belling 3 cu. ft. / 85 liter Upright...
How do make my mini fridge colder there is a knob from 1- 10 is lower colder or warmer
Hi!
Here's an answer for you:
Setting the fridge knob to 10 will get it to the coldest possible
That means, lower is WARMER
Best regards!
Aug 09, 2011 | Sunbeam Refrigerators
I have a kenmore freezer upright large is 6 colder or 1 the coldest
The higher number is colder and the lower is warmer....or 1 warm and 6 coldest...
heatman101
Aug 28, 2010 | Kenmore Freezers
What number makes the refrigerator colder the #1 or #8 we can;t find our book.
Try turning the control all the way in one direction until the compressor stops. Wait five minutes and then turn to about half way like #5 on most. The closer to off is warmer and the further beyond is colder #5 is the typical setting to begin with. Off then 1 2 3 4 5 6 7 8 9 10=> coldest, Sea Breeze
Feb 09, 2010 | Kenmore Refrigerators
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
I have a Bevair DD58 and it won't stay cold. I
the three weeks kinda tips us off to a leak in the sealed system
check your sradder valve for a proper seat
and make sure your joints are clean and complete
Oct 13, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Beverage-Air DW49 Stainless Steel Beverage Cooler Commercial Logo
276 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
