Question about HP Pavilion a705w PC Desktop
How to disable firewall connections on an HP
I am trying to connect my ipod to a new computer and when i plug my ipod in it says something about firewall connections and will not let me do anything with it. i need to diable the firewall connections but am unsure how to do so. please help. thanks.
    Scholar:
  • 118 Answers
Disable Windows Firewall in Windows XP SP2 or SP3 loadTOCNode(2, 'summary'); NoteBy turning off the firewall, you leave your computer open to attack.Therefore, before you turn off your firewall, disconnect your computerfrom all networks. This includes the Internet.
To disable Windows Firewall, follow these steps:
  1. Click Start.
  2. Click Run.
  3. Type Firewall.cpl, and then click OK.
  4. On the General tab, click Off (not recommended).
  5. Click OK.
FOR WIN_VISTA
1. Open Windows Firewall by clicking the Start button , clicking Control Panel, clicking Security, and then clicking Windows Firewall.
2. Click Turn Windows Firewall on or off. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Click Off (not recommended), and then click OK.
rate me if it helps..
regards,
Posted on Dec 04, 2008
2 Suggested Answers
  • 265 Answers
SOURCE: how to disable firewall connections on an HP
As its HP im guessing you will have Nortons Anti Virus Running On The System, If You Left Click This For A Minute And Press Disable That Should Disable Your Firewall.
Also have you tryed to run itunes, as once that is installed your firewall should let you gain access to the Ipod
Posted on Feb 16, 2009
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Jan 13, 2011 | Apple iPod touch
My brand new hpc4780 photo smart printer is not working. When I connected with an HP adhoc connection, it worked fine. So, HP advised that there is probably a firewall on my netgear router blocking my...
Hi, i have the same issue and it isnt the firewall. But here is how to disable it if it is. Go to the router websight at 192.168.0.1 (type this directly into the browser bar at the top of your page. The password is usually password in lowercase. The username is admin. This will get you into the management screen for the router config. Look on the Left and you will see firewall. Click on this then ensure that there are no restrictions for HP.
I still have the issue with the printer so good luck.......scotty
Sep 13, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Just got a HP laptop for work that's running windows 7. It won't find our HP 5610 printer at home even tho I've downloaded the right driver
Is the printer directly connected to the laptop by a USB cable? Try a new cable. Check that the USB ports work by plugging in a known working device.
If you are using a print server or USB hub, try a direct connection. (If networked, check that your firewall isn't blocking the access by disabling it. If the print server is another computer, make sure that computer's firewall isn't blocking the laptop (trust level between the two machines).
I hope this helps.
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
I have an 8 gb ipod touch that is now disabled because I can't remember the 4 digit code. The message on the ipod's screen says 'ipod is disabled. Connect to itunes.' The computer that I originally used...
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
May 20, 2010 | Apple iPod touch
Ipod is disabled connect to itunes
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
Ipod is disable and showing connect to itunes
You might be able to restore the iPod, you just need to put it in a different mode. Try plugging it into your computer. Press and hold both the sleep and home buttons at the same time until the screen goes black (can take longer than 10 seconds) then let go of the sleep button (the button on the top of the unit) while keeping the home button held in (the button on the front of the iPod). Keep the home button held in until your computer recognizes new hardware. You should hear some sort of sound coming from your computer speakers. That and the "installing new hardware" notice should come up in your taskbar (this is where you computer shows the clock). Let go of the home button once this happens. Open up iTunes and then restore it.
Just a little FYI - it may take longer than 4 minutes before you can a response. You might want to wait at least a few hours before bumping your thread. Remember that this is a normal work week and not everyone is on these forums during normal working hours (ie 9:00 AM to 5:00 PM). Most of the traffic here on iLounge is during the evening.
Feb 24, 2009 | Apple iTunes
Feb 16, 2009 | HP Pavilion A1130N Athlon 64 3500+ DVD+RW...
Limited/No connectivity
If you are using a WAP encryption try using WEP and try disable some of your anti-virus and firewalls,
try also assigning an Static IP for your computer..
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
HP Pavilion a705w PC Desktop Logo
1,162 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
