Question about Canon Office Equipment & Supplies
What is imput voltage for Canon Pixma printer ip1000? 240V or 3o DC?
    Scholar:
  • 149 Answers
Power Source: AC 220-240V, 50/60Hz
as listed by Canon
Posted on Dec 04, 2008
My PIXMA MP970 printer abruptly lost power. is it due to fuse problem and where is the fuse box?
Dear
The printer has the step down SMPS which supply the low voltage (generally 24V DC to the other component. It contains high voltage risk also the high frequency. Sound knowledge is required while repairing the SMPS also appropriate precaution. If somebody is present having electrical knowledge during repair is better.
First disconnect the electricity supply cable from the printer
open the smps, check visually for any physical abnormality of individual component, then check the fuse for open,if its open check the MOV,mosfet,capacitor,bridge/zener diodes for short if found replace with same value,
take a series lamp of 15W incandescent bulb, connect the smps, check the voltage at secondary output. utmost care should be taken with attention of co-worker while checking live circuit.
If there is no voltage, check primary component at area of PWM IC /replace PWM ic (smd).
Again FATAL ELECTRICAL SHOCK AND FIRE MAY HAPPEN IF CARE NOT TAKEN.
Thanks.
Feb 13, 2015 | Canon PIXMA MP970 InkJet Printer
How do I fiux \ how do I fix error code 6500 canon pixma iP6600D
6500 Other hardware error often this means
logic board or ac/dc adapter is not working properly or dead
Feb 11, 2015 | Canon Pixma iP6600D InkJet Photo Printer
It will not trurn on does the ac adapter need replacement it is over 10 yrs old
Look at adapter, see what output is supposed to be- maybe 12 volts DC? Find a multimeter that will measure DC voltage, and see if the output plug has that across the connector. If you have an ordinary power cord without an adapter, it will have 120 volts AC like any other cord, which you can also measure on AC scale, but be careful as you can get a dangerous shock, just like you can from an ordinary household outlet.
Note: AC voltage may vary by country.
Apr 09, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
The power went out and now my canon mp530 all in one printer won't turn on...the power supply seems fine...so what could be wrong?
You said the power supply `seems fine', have you removed and tested it? there should be dc voltage present. I cant remember the voltages, I think +24VDC, but it doesn't matter, either you have it or you don't.
If the power supply is good, then the problem is most likely the logic board, and is not worth repairing.
Oct 31, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How can i install a canon pixma ip1300 without cd, i lost my dc installer
Hi arivle,
Just go to Canon official site,choose your region and nearest location (country). Click Support & Download,Choose the following: Inkjet Printers in product category, Pixma in product series,Pixma ip1300 in product models,Driver & Software in type of documents,Select appropriate driver for OS, and check in the box: I have read and understand the information above, and wish to download the designated software. At last clikc Download.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 22, 2008 | Office Equipment & Supplies
Error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
see if that helps
Robert
Please rate this solution thanks
Aug 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon printer PIXMA MP 150
I think this may work.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jun 29, 2008 | Canon PIXMA MP150 All-In-One InkJet...
94 people viewed this question
old marine
old marine
