Question about Minolta EP4000/5000 CS/PRO Copier
I thinking of buying one of these machines
Is this Minolta CS Pro 5000 sttickly a copy machine or is it a printer also?
  • Minolta Expert
  • 1,326 Answers
The Minolta EP-5000 is a analog copier. That means that it can not be connected to a computer to print to, it is just a 50 a minute copier.. It is to old to be connected, it came out around 1996 or so..... It is naot a bad copier, it is one of there old work horse... It is a up-dated version of the EP-3050 & 4050.
Posted on Dec 05, 2008
Minolta 4000 insert key
There is device slot where the Key Counter goes who ever owned the machine before you had it set up like at Kinko's where you get a key from the store make your copies come go back to the employee and they determine the number of copies you made. Mite want to get the key previous owner.
Dec 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
My minolta ep4000 copy machine print the pages black why?
Clean the optic sisitem componenets,mirrors(4 mirrors),lens,original glass,clean the erase lamp obturation filter(located in OPC drum area,clean the drum charge corona unit(wire,grid).
Mar 09, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 4000 Copier shows: Call Maintenance M4
stop 0 stop1 sets the machine service mode. select consumable clear the copy kit counter
Mar 31, 2012 | Minolta EP4000/5000 CS/PRO Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Smudge on the paper
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Feb 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Is the Minolta cs pro 5000 strickly a copy machine or is it a printer too?
Im pretty sure this is an analog machine. One way to test this for sure is to make multiple copies of one original. If the light scans the paper each time, then it is a analog machine and can't be hooked up to a computer. Digital machines generally scan the document only once then print many.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Services
what kind of problem are you having, please be as descriptive as possible.
thanx,
mikey
Mar 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
127 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
