Question about Garmin iQue 3600 GPS Receiver
Repair for 'locked up' Garmin iQ3600 PDA/GPS unit
Generic problem for all GPS Devices This is my 3rd posting of the problem, and have not received answers of ANY kind. It is as if the questions don't exist, but I have no one to complain to. I submitted a question for GPS var g_tryMail = 0; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse posted by ael21012 on Dec 03, 2008
I submitted a question for GPS repair, on 12/02/08. I also paid to my account $15.00. I have not recieved a solution or any answer to my problem question. How much longer must I wait, which I am willing to do if the time is reasonable.
Arthur Lederle Comment posted on Dec 03, 2008 E-mail ID # 40 from FixYa requested me to resubmit my question. I have a Garmin iQue 3600 GPS/PDA unit that is in a hard 'locked up' stage. Because of a previous problem, (unit went into a 3 screen loop only when it was in GPS map mode'). All other functions worked ok, until I opened the antenna to start the GPS. Since this was a 'constant loop', I tried to update the unit's software. I downloaded Release 6 from Garmin along with their instructions on installing the upgrade. All went well until I neared the end of the instructions. I was requested to do a 'soft reset', which I did. The unit would then turn off for a few seconds, then turn on again displaying the 'PalmPowered' screen, which it did. I was then told to follow the instructions on the next screen. Before I could do anything, a screen containing a 'reset' button in it came up. I tried to do the reset by taping the reset button in that screen, but nothing happened. I did a 'soft reset ' again, but the same sequence of screens followed. OF MORE CONCERN TO ME AT THIS TIME, IS THAT I CANNOT TURN THE UNIT OFF.
Must I let the battery run down, or is there a way to get out of the 'hard freeze'? Because of this lockup, I cannot get to any of the PDA functions, making the unit useless. I went tnto a little more detail for this SECOND description of the problem.
Thanks,
Arthur Lederle
SOURCE: Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Posted on Feb 28, 2008
SOURCE: need to find someone to repair Garmin iQue 3600
We Carry out repairs on all makes and models of Sat
Nav's Including the likes of Garmin, Tom Tom, Navman
etc.
It sounds like you have damaged the charging/power
circuit due to a power surge. We can repair problems
like that 90% of the time. It just depends on the
extent of that damaged caused from the burnout.
Our Team of engineers are highly skilled and can
handle repairs down to component level.
So give us a try ...
www.satnavrepaircentre.com is a UK Based company.
Hope this info helps..
Regards,
John
SatNavRepair Team
Posted on Jun 26, 2008
  • 12 Answers
SOURCE: My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Posted on Oct 08, 2008
SOURCE: Unlocking IQue 3600 maps
Make sure the maps are supported for your device . Not all maps are compatible. If you look up the IQ3600 on the Garmin website you will see the maps that it supports.
heres a link
https://buy.garmin.com/shop/shop.do?cID=165&pID=328#mapTab
Posted on Oct 28, 2008
  • 8 Answers
SOURCE: dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Posted on Mar 21, 2009
All of a sudden, my Garmin SP 7200 lost all satellite reception. All the signal bars are blank. Garmin says $190 to repair. Really like this unit but considering another unit. Is the GPS receiver...
Try running and installing or reinstalling the latest update using the Garmin WebUpdater.
download the latest version of WebUpdater software
Usually this will resolve most issues.
Failing that, the GPS receiver is replaceable as per Garmin's $190 to repair.
Aug 18, 2011 | Garmin StreetPilot 7200 GPS Receiver
Hello, I have a model 1350 and it seems locked up and will not recieve satilite signals?
Try giving your unit a firmware update using Garmins WebUpdater software, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp. If this dosent work your units GPS receiver is probably dead and should be sent in for repair.
Hope this helps!
Feb 18, 2011 | Garmin nvi 1350T 44 in Car GPS Receiver
I have a Garmin 3600. When I want to use the GPS feature, and I open the antenna, all I get is Acquiring Satellites, but nothing happens (the little indicatior on the bottom shows activity). I thinkthere...
If you can obtain an external antenna from another IQ3600 user it
will plug into the connecter on the top of the unit and bypass the fold out antenna. I had to buy one because the windshield in my Pont Montanna would block the satalite signals. When I plug in the external antenna I do not have to fold out the antenna on the unit.
That will check to see if the unit is recieving and /or if the fold out
wire is broken. The external antenna is not Garmin specific but the
plug on the end is so another gps antenna with the same end plug works.
Aug 16, 2010 | Garmin iQue 3600 GPS Receiver
When syncing my iQ3600, I get the following message: system compatibility.c,Line:69,invalid card# I have tried resetting, but the message will not go until I erase all data. The maps etc are still on the...
Contact Garmin Customer Support to resolve this problem.
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Feb 06, 2010 | Garmin iQue 3600 GPS Receiver
Battery replacment
this is one of many hits on google for batteries You should shop around a bit to be certain the price is fair. If you Pay Pal they will usually give you some buyer protection as well.
Here it is
http://www.longlast-battery.com/landing/index_products.asp?idProduct=2880&SubCat=88&Cat=6&gclid=CLTYzf2xxJsCFRPyDAodg0QsBQ
or you can google
garmin iq3600 battery replacement
Jul 07, 2009 | Garmin GPS
Dark screen on garmin ique 3600 pda
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
Even with the maps unlocked it they can appear to be locked.
There are little known flags to diable/enable the base/detailed maps.
Check that the boxes are checked under the <Map><Options><Misc>
You can select either base or detailed maps there.
Disable both and it looks like the unit doesn't have any maps.
Aug 21, 2008 | Garmin iQue 3600 GPS Receiver
When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Sep 18, 2007 | Garmin iQue 3600 GPS Receiver
"Screen has Broken"
Have you checked Fixya's repair directory found here http://www.fixya.com/ServiceCategories.aspx ?
May 23, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
59 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
