Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Hi there I have casio EXLIM ex-7270 thge problem is the red signal aways blinking I try to revome the battery several times but the problem still there cant use pls help thank you
SOURCE:
  • 374 Answers
SOURCE: Charging of the casio exilim battery
Blinking light means charging error. Call tech support and they will replace battery for you for free.
Posted on Nov 26, 2007
Yazz226
  • 497 Answers
SOURCE: CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
Posted on Jun 13, 2008
  • 4 Answers
SOURCE: The battery (NP-20) for my
Okay I just fixed this on my camera the same thing. First make sure your battery is charged. You will need to get a paper clip. Take the battery out and unfold the clip so that you can use it to pull up the contacts between the battery positive and negative and the camera. The conductors need to touch the positive and negative on the battery. If you battery is dead you will need to do this as it will not charge your battery on the cradle becaue there was no connection. over time I think that the battery loses its connection and the spring is not strong enough to push up the battery far enough. I ordered a battery charger and new battery and it still didnt work so I started to tinker with it. I held the battery with my finger pushing it up and holding it, and simaltaneuously powered on the camera. Thats when I figured it wasnt the battery but it wa the connection with the battery and the camera.
hope that helps
Posted on Apr 28, 2009
SOURCE: Casio Exilim EX-Z850 Red Light Flashing
I have the same problem but could not find any solution as yet. My work around is to switch of the flash and shoot with manual controls - of course that only works well when using a tripod or someting similar. I think it is a bug with the flash loader wich seems not to give the go for shooting until flash preload is finished. If anybody has a real solution I'd be happy to read. cheers e
Posted on Jun 11, 2009
BillB-SA
  • 2761 Answers
SOURCE: Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Posted on Oct 17, 2009
I have a casio exilim ex z77. My battery to my camera wont charge when I put it on the charger. The red light just blinks.
hi, once you charge your battery and the red light blink it means your NP-20 battery is damage and you need to buy new one.TIP- charge 1.5 hours only and if youre not using you camera for a long time its better to remove the battery.
good luck and thank you my friend
Jul 08, 2010 | Casio EXILIM Card EX-S770 Digital Camera
I need to down load the drier for the Casio Exlim Ex 275 ER X275 Drier
hi,
visit to the given link for driver..( see at the bottom of the page..)
http://support.casio.com/download.php?cid=001&pid=145&rgn=1
Jul 07, 2010 | Casio Exilim EX-Z57 Digital Camera
Casio Exlim Z6. Lens stay out when camera is
Please view my FixYa Tip on this subject for a complete walkthrough of the potential causes and solutions.
http://www.fixya.com/support/r3556007-camera_lens_stuck_or_wont_retract
Many thanks for using FixYa.
Dec 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Oct 16, 2009 | Casio Cameras
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
CASIO EXP600 Flash problem
Hi, I sent my camera to the dealer...thanks anyway, Sevendata
Apr 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
41 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
