Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Dec 04, 2008
GHW925OML2 Leaks with full load, shuts off during spin cycle
I used my friends Duet HT, not really knowing how it is supposed to work. So, now it can only take half a load or water will leak everywhere. Also, it won't finish the spin cycle. It starts flashing 2 minutes and it has to be shut off. About a half hour later, the spin and drain cycle can be activated to finish the load. What is wrong? Also, can I get an manual?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
297
Points
You can get a manual at amazon.com.
  • Anonymous Dec 11, 2008
    oops! that's not amazon, it's e-bay, and it's a repair manual, not an owner's manual. check the model # to be sure it's for your machine or close enough to your machine.
    there is also a repair manual online for free for one model of duet (just doesn't happen to be mine)
1helpful
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
1helpful
Whirlpool duet ht washer make loud thumping sound during spin cycle
you could have a broken shock but most of the time it's a damaged spider gear and you'll need to replace the washer because the part alone is 500 bucks.you're using to much detergent and it eats at the spider gear and it falls apart
My duet ht front loading whirlpool washer goes through a complete cycle then during the spin and drain ( the last cycle) it displays a f6 notice and will not complete the cycle, you cant get the wet...
Hi
Thanks for using FixYa. Error F06 in your washer indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
1helpful
2answers
Whirlpool Duet Sport HT - Left Front occ. leaks a lot of water
hello. i dont have to tell you that these intermittent problems are often the most difficult to isolate ...........sooooooooooooo lets look at all of the possible causes for your machine leaking
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Whirlpool Duet ht...does not spin out?
run it with no clothes, wait the entire cycle because it only spins fast at the end, dont overload the machine.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
