Question about Princeton Digital VL1918 Monitor
Princeton VL1812 turns on then off
Monitor turns on then screen goes blank but power light stays green. manufacturer says possibly a back light? Is this repairable or should I scrap?
5 Suggested Answers
SOURCE: Monitor will not display
Hello, tech support online at Sony was able to help me correct the problems.
Posted on Mar 09, 2008
budmrtn
  • 11361 Answers
SOURCE: i have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Testimonial: "thank you the explanation sounds like its right on the mark. Unfortunately, I see these being sold used for under $50 so it is not worthwhile for me to repair as I don't have the expertise and I would think I would be charged at least that by a shop.I was hoping there was a reset button as I think the monitor succumb to an outage. Thanks again. "
  • 196 Answers
SOURCE: my 15 pin rgb cable is missing 2 pins on my
Try going to www.cables.com
Posted on Jul 24, 2010
  • 1684 Answers
SOURCE: where can i finde the
We have that cable in stock. You can get more information at:
http://www.ccl-la.com/catalog/product_info.php?products_id=54
The cable runs $4.50 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Nov 17, 2010
elix0411
  • 3530 Answers
SOURCE: My Princeton 17" Monitor display
Welcome to Fixya
First thing to do is to check all physical connection of the monitor if both ends are intact. Install the driver of your video card. If you have other computer, try to plug in the monitor to that computer, just to make sure that the video card of the 1st computer is not the problem.
Please reply back to this email for any update.
Thank you for using Fixya!
Posted on Jan 26, 2011
VL 1716 monitor. The display blanks out after 20-30 seconds. When I turn the power OFF anf Back ON, the display comes back normal, then blanks out agin after 20-30 seconds. The power light stays green.
This is due to system goes to stand by mode or Hibernate mode. To disable, go to power management and disable or incrase the time for the same.
Revert back for more assistance. Also give your valuable feedback/rating on the same.
Feb 08, 2010 | Computers & Internet
My princeton VL2018W will flash the screen when first powered on but goes blank after. With repeated unpluging, the display used to stay, but no luck
99% will be bad caps in the power supply section. Take the back off and look for caps with bulging top, replace them with good quality caps such as PANASONIC FM or FC series from DIGIKEY.
Jan 05, 2010 | Princeton Digital VL2018W Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Princeton VL1715-1 no display
From what you say there is probably not much you can do with it, the parts inside are SMD, to small
to work on. If you could still see txt on the screen when you shine your torch, it could be fixed by
replacing the back lighting PCB.
Hope this helps
Have a nice day.
Dec 22, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Mar 08, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
PRINCETON LCD-15BLK MONITOR
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Princeton Digital VL1918 Monitor Logo
157 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Sunday Ojelabi
Sunday Ojelabi
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
