Question about Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422
Kenmore upright freezer
Freezer is about 6 years old and kicks on for about 5 seconds and then shuts off repeats every 2-3 minutes any ideas?  model # 253 20402000
    New Friend:
I like pizza
Posted on Aug 19, 2013
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
aborcass
  • 2651 Answers
SOURCE: Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Posted on Mar 03, 2008
mikeh77586
  • 9 Answers
SOURCE: Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Posted on Nov 12, 2008
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
  • 6 Answers
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Posted on Jun 14, 2010
My freezer start only a few sec. After 10minutes start again
Roy,
Sounds like something is causing your compressor to kick the overload. It could be the overload itself or it could be the start relay or it could be a locked compressor. Probably best to call a service tech.
Apr 29, 2015 | Freezers
I have a woods freezer model # V17NAB I defrosted it and after all cleaned ou I plugged it back in. The compressor kicked on but shut back off about 30 Seconds later and will not stay running. It turns...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 22, 2010 | Woods Freezers
Freezer runs for 2 seconds then stops, and runs this cycle.
Good day,
The shut off is due to the protective overload mounted on the side of the compressor to shut it down, if it can't start.
On the side of the compressor is a cover box that contains the overload device, a start relay, and on some models, a start/run capacitor.
These items can to a degree tested with an ohm meter, but it is wiser to take them to an appliance parts house for testing.
If any are found defective, replace them. If not, the compressor has failed internally and needs to be replaced. Close to $400.00 if not more.
Feb 06, 2010 | Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Is Freezer Motor On The Outs?
The over current protection relay needs to be checked out. Usually it is mounted on the compressor or nearby. Unplug before attempting repair.
Aug 04, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422 Logo
272 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
