Question about Brother IntelliFAX 4100 Laser Fax
Incoming Fax is blank
Tran Report prints okay. I can send faxes.
  • Matt Dasse May 11, 2010
    is it from all locations or just one?
    Champion:
  • 320 Answers
PRESS REPORTS IT WILL PRINT OUT A HELP PAGE LOOK AT THE SUB MENUE ON THE HELP PAGE MENUE SELCTION 3 FOLLOW THE PROMPT TO TURN ON THE RECEIVE OR IT MAY SAY EASY RECEIVE . GOOD LUCK BROTHER TECH / I HAVE THE SAME MACHINE AT HOME GOOD LUCK
Posted on Feb 07, 2009
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I can send out faxes and they recieve them but when they send me a fax it comes up blank
Try printing a report using the report button, if it prints blank, your laser unit might be faulty.
Nov 20, 2009 | Brother IntelliFax-2820 Laser Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
NOT PRINTING SENT FAX REPORT
Make sure your in fax setup your message confirm is ON and not on ON-ERR. The Sf-560 also has an issue with the phone jack on the back becoming loose and causing sataic. Needs to be resoldered
Mar 26, 2008 | Samsung SF-560 Plain Paper Laser Fax
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Brother IntelliFAX 4100 Laser Fax Logo
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
