Question about Canon MP610 Photo All-In-One Printer
Ink Cartridge I have mislaid my manual for the canon mp610 and need to change an ink cartridge, could you please walk me through the procedure so that I can change just one cartridge and not all of them thankyou How to install a black ink cartridge
  • 105 Answers
If you go to the site below you can download a manual to have on your computer for easy reference...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15604
Posted on Dec 04, 2008
How do you change the printer cartridge, please? I have mislaid my manual.
First make sure that the printer is on and the front cover and output tray are open. Next open the paper output cover by rotating it down towards the output tray. The ink cartridge carrier should move to the ink replacement position on the right side of the printer. Push the cartridge lock lever down until it clicks to unlock the cartridge that you need to replace. (The color cartridge is on the left.) Pull the cartridge towards yourself to remove it. Now open the replacement cartridge packaging and remove the protective tape from the cartridge. Push the new cartridge fully into the open spot from removing the old cartridge. (The label should be up and the copper covered sections should be down and facing forward.) Now push the cartridge lever lock up to lock the cartridge in place. If the lever doesn't move, check that the cartridge is fully forward in the slot. Finally close the paper output cover. Wait for the printer to complete the print head clean cycle before using the all-in-one.
Note: only remove and replace one cartridge at a time. Work quickly to minimize the chance of the ink system drying out after removing the protective tape.
Canon has the steps to change any ink cartridge on the Pixma MG4250 support site in the FAQ labeled Replacing an ink cartridge. The full text and pictures are available here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg4250.aspx?type=faq&search=1&searchurl=/support/consumer_products/content/faq/?itemid=tcm:14-1276595 . You can also get the User's Guide and other documentation here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg4250.aspx?type=manuals&language= .
I hope this helps.
Mar 22, 2016 | Canon PIXMA MG4250 Inkjet Multifunction...
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Jun 18, 2009 | Canon MP610 Photo All-In-One Printer
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
Ink Cartridge
I JUST FOLLOWED INSTRUCTIONS AND IT WORKED THANKS SO MUCH
Nov 20, 2008 | Canon MP610 Photo All-In-One Printer
I have lost my manual and can't find out how to change an ink cartridge.
Hi there my name is Alex and im here to help solve your problem
Here is the manual for this printer. Please follow this website. http://www.generalmanual.com/Printers/Canon-PIXMA-MP610-Photo-All-In-One-Printer.htm
If you have any problems, please let me know
Oct 11, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP610 Photo All-In-One Printer Logo
165 people viewed this question
old marine
old marine
