Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
GOES TO DEVICES AND UPDATE THE DRIVER, IF IT DOEN´T WORK YOU NEED TO UNINSTALL THE AUDIO DRIVER, RESTART YOUR HP AND THEN GOES TO HP SITE FO FIND THE RIGHT AUDIO DRIVER. GOOD LUCK
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
You better take a look at HP's website.. maybe you will need a slightly different driver, since your computer is not exactly the same as mine. I'm sure the sound card is the same, but better safe than sorry. good luck!
Check when you plug in the headphone the laptop speakers get off or not also see the audio configuration under control panel sound that you choose digital sound or its having channels system like 5.1 or 7.1 channels you have to configure it to headphone
