Question about Ebel Classic Wave 9090F249725 Wrist Watch
Need a new stem. Can I purchase on and get it put on myself
This womans wave watch is 12 years old, and I can not pay $300 to get it fixed
  • 2,334 Answers
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
Posted on Dec 17, 2008
Sector model 31723 broken stem
An independent watch repairman (used to be one at every jewelry store) can probably replace the stem of your watch for far less money, depending the damage you describe. I suspect that the high repair price given to you by Sector means that they would simply drop a brand new movement into your watch and give it back to you. In most cases, though, a replacement stem wholesales for $7-20, and you might be looking at $30-75 in labor, depending on where you live and the type of watch repair shop you're able to find.
When looking for a repair place, I would stay away from the big chain jewelry stores--and also the "while you wait" watch battery shops. Neither of those operations typically has an in-house person with the right expertise to fix your watch.
When all is said and done, it is possible that the nature of the stem break will require more expensive repairs to your watch. A good repairman will tell you if that's the case. Even then, $400 seems very high to fix this problem. In the old days of even 10 years ago, this would be a $25 repair!
Best of luck with your quest.
Dec 02, 2012 | Sector 2653940025 Wrist Watch
The day inscription is two days late, monday, watch says saturday
So to change the Day and Date of your Watch, slowly pull the Stem out... (Do note that if you have a Waterproof Watch, you'll need to unscrew the Stem counter-clockwise, which is towards you, until it unlocks, then you can pull the Stem out!) But this is where you need to go slow. If you pull it out slowly you should hear one snap. (It stops on the first notch) If you pull the Stem out all the way, it snaps twice and ends up on the second notch. (See picture below) The second notch, or all the way out, is where the Stem needs to be to set the Time.
day-changed.gif But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date!
Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch!
If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle.
Jun 27, 2011 | Watches
I pulled the stem out completely trying to reset time.
try to a authorized seiko service center!they are not expensive!the only think that your watch needs is anew winding stem costs 3-4$!the job isnt difficult for a good watchmaker!the jwellersin watch service are the same as you buying soap from a barber shop!
May 14, 2010 | Seiko SUJ051 Wrist Watch
if you broke the stem and its left a peice inside the movement then i would ask your repairer for a module exchange this is cheaper than servicing and a new crown 55.00 or send it back to seiko they are very good with there prices.you wont have the tools you need to replace it yourself..
Mar 25, 2010 | Seiko SUJ051 Wrist Watch
My watch the bezel that you change the time / date with, when pulled out comes all the way out, can not change time. Watch less than a year old, can not find the warrenty, not the end of the world, do not...
There are two possible causes: settting lever in your watch is broke/out of engagement or stem is broke. Not a big deal, but watchmakers skills are needed to fix it, as watch must be dismantled.
Any decent watchmaker can do it, so, just find your nearest watch repair shop and ask to fix it. Prices may vary, but no more than 25% of the cost of watch itself.
P.S. It is called Crown or Winding Crown (you say bezel).
Rate me, please.
Aug 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Ebel Wave lady's watch battery
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
Feb 19, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
Casio wave ceptor 3747
Use this link to read Direct Casio manual:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3747.pdf
I suggest you may need to wait till the first signal is received by watch.
If all this doesn't work, then check the battery condition- it may be underpowered and need replacement. Eve if your watch is brand new, the battery may be few years old.
Do not forget to rate, please.
Jan 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The stop watch second and minute do not reset to 12 . Dallas
To reset the stop watch unscrew the stem and pull it out 1 click. Then press the buttom to the top of the stem and it will move the minute stop watch 1 minute continue to press to get it set to 12. Do the same with the bottom button to get the second hand stop watch to 12.
Sep 01, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Ebel Classic Wave 9090F249725 Wrist Watch Logo
154 people viewed this question
Top Ebel Watches Experts
Coss
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Ebel Watch Expert? Answer questions, earn points and help others
