Question about HP Pavilion dv6000z Notebook
HP DV6000 Battery problem
I have a HP DV6000 and recently my power jack went out and I could not charge my laptop battery. Now it was charging with the older power jack, but I took it to a computer repair shop and got my laptop back and now it will run while on charge, but take it off charge and the battery will say 0% remaining. I have tried a new battery, reimage computer, everything i know of and it still shows 0%. I did run the battery tester and it said that my battery was invaild so I got a freinds battery (who has the same computer as mine) and it still said the same thing. I travel alot and this computer must come with me and be able to run on battery. Please help.
Thanks
    Problem Solver:
  • 8 Answers
Maybe your adapter can't work correctly? Check the adapter! If its tested well, you hp pavilion dv6000 battery must be returned to the repair shop again!
Posted on Apr 08, 2009
  • 64 Answers
Bring it back to the repair shop if it has still repair warranty. They should take care of it.
Posted on Dec 04, 2008
HP dv6000 laptop not charging problem, adapter, battery and power jack looks like it works fine
If your battery, charger, and DC Jack are ok, then the most common problem is the surface mount transistors on your HP's main board called MOSFET's. They are small 30V N channel 8 pin components soldered to the main board. The boards also have transistor circuits which switch back and forth between a charging and discharging state. However these rarely ever fail. The MOSFETS fail because of the thermal loads which they must endure. Although some notebooks (like the Gateway I'm currently on) have a DC jack which serves dual purpose of supplying DC 19V AND connecting/disconnecting charging circuit. However your HP dv6K does not.
However it's worth mentioning that these models have had all sorts of problems...most notably poor thermal design to begin with that usually creates solder connection problems with the main chipset especially on AMD models. Good luck.. :)
Mar 27, 2013 | HP Pavilion DV6500T Notebook
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
HP laptop battery problem
Hello :
Try another battery . If it's the same problem , then there must be a problem with the charging jack or the charger or power cord .
good luck .
please rate !
Apr 03, 2010 | HP Pavilion zd8000 Notebook
HP Pavilion dv6000 plugged in not charging, I have a new battery.....PLZ Help.
Its the DC charging jack that you plug the charger into on one of the sides of the laptop. Do a google search, go and search for "HP dv6000 DC jack problem charging" (leave out the quotes) and you will see this is a common issue with the dv6000 and laptops in general. Many will just replace the whole laptop motherboard as the DC jack is attached to the board. If you know what you're doing, you change out the jack, quick repair job and keep your own board, but fixed. I would fix it if it were mine. You may be able to find someone local online but if you need someone to do the repair, I'm in the repair directory, as are many others qualified.
Note: It may come to a point, or the situation may just fit better to replace the entire board instead of the port alone. This is usually when the jack is not seated and easily replaceable, or if you are under warranty, HP will replace the whole board.
Mar 08, 2010 | HP Pavilion dv6000 Motherboard
Pavilion dv6700 AC Power. My DV6700 performs perfectly on battery, but will not charge the battery or run straight off AC. AC Adaptor, Batteries and AC jack have been tested in fine working order. Any...
Hi, believe it or not?; sometimes the current in certain areas of the home or apartment have separate power circuits from the main direct current system. Check to make sure there is electrical current running through your socket, and or light switch to open the circuit. Thanks, paul7of9
Dec 29, 2009 | HP Pavilion dv6000z Notebook
My hp laptop won't start.
This is more than likely whats going on
HP website says what to look for
"HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000."
Good luck..
Aug 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP DV6000 Won't Charge
The charging process is suspended temporarily because the battery has overheated. My brand new DV5 (3 weeks old) does the same, because it's really hot here.
Turn the laptop off and the battery should charge. Also, when you do not need the battery and are running off the mains, remove it from the laptop. Keeping a battery at 100% wears it 4 times faster than doing regular charge/discharge cycles.
Jul 02, 2009 | HP Pavilion dv6000t Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
178 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
