Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 Flyback Question
Hello, I was just wondering exactly how do you disconnect the wires going into the flyback to be able to remove the board to do soldering. Any help would be appreciated. I can tell that I need to replace the flyback but want to try resoldering the connections first.
  • Casey388 Dec 21, 2008
    I checked the capacitors and they all look fine. I did find some capacitors that were blown on the board that connects to the RCA jacks on the back of the television. But on with my question, so the red cable comes out but they give a replacement. On the black cable, do I just have to pull that straight up to remove it from the original flyback?
    Genius:
  • 1,139 Answers
The wire comes out by pressing the two tabs in and pulling real hard, You will be happy to know that the replacement IHVT comes with a HV cable since 9 time out of 10 you end up damaging the IHVT cable connection. In any event before checking the IHVT I would suggest looking at CP150, CP120 and CP140 to see if they are puffy, since this is a common problem in this set.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
  • Henry McKelvey
    Henry McKelvey Dec 21, 2008
    Hello Casey388,
    Technically the only cable you have to remove is the red cable. The black and white cables are fixed and have to be removed from the focus block and the CRT connector board.
    I hope this helps,
    Shuttle83
    http://www.electron-age-technologies-llc...
R56wh78 rca 56 in.. need help .. was wondering if any one new how to remove the wires from the flyback.. the ones that sit on the flyback itself.. or do they even come off.. i am replacing my whole...
your model has the 270125 which has sealed wires in the flyback which cannot be removed they have to be removed from the other end UP front and have to stay in the flyback.
Aug 17, 2011 | RCA Televison & Video
Rca 52" 3 light flash not turning on
Check circuit board for bulging at the top capacitors. The board you are looking for is the one with the flyback transformer. This transformer is the one with a thick red wire going to the top of it. Replace all bulging capacitors. Capacitors are the ones that look like little cans. While you are there resolder the bottom solder points on the flyback transformer. This should work, because it worked for me.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback install
IT twisted off turn clock wise and wirer should come out red is easyer to remove,1 goes to high voltage tripper red black goes to focus&screen drive controls.
Sep 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hdtv:
The flyback Number 259296 is available at the following link with free instructions, or they also have the ITC222 deflection board as well which is the board with the flyback on it.
http://servicemanuals.vstore.ca/
Sep 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA
The flyback is the big black thing on the deflection board. usally has big red wire coming out the top. THe three small rectangular items are special fusable resistor. or fuses
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 flyback question
If your model number is D52W20 you need flyback number 259296 and you can get a new flyback at the following link and they will givce free online tech support to walk you through the removal and replacement procedure.
Jul 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback Transformer
Flyback transformers rank about a 5 or 6 on dificult to repace.. depending on the model of tv that you are working with.. the rca itc222 can be difficult.. dependend on your soldering experences. To replace this one you have to pull the chassis tray up and out to get to the bottom... unsolder the pins ussally a vacum desoldering tool is required because it is important to remove all solder from the pins..then gently pry the clips that hold it on the board... this is where you can mess up unless the pins have be completly solder free you can crack the board... NOW the hard part... removing the wire from the flyback.. if the flyback is the type that the wire comes out. the wires will eather have a clip around the large wire or you will have to go to the other end of wire and pull it out from the splitter. eather way this wire is firmly in an will require gently but extremmly firm pulling to get out.
May 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20
You will need some solder wick to remove the old solder. You need to heat up the old sloder with a solder iron and while its molten touch the solder wick to the solder and the wick will absorb the old solder. You will need to keep trimming the solder wick end so it will keep soaking up the old solder. Do that to all remaining pins on the flyback. The replacement flyback will not come with the high voltage wire attached so you will need to remove the wires from the flyback. This is accomplished by twisting the wire 90 degrees while exerting upward pressure. Instalation is the reverse of removal. Let me know if you need additional assistance.
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20
the flyback is the transformer with the RED wire that resembles a spark plug wire you can get one at the following link for under 50 dollars and comes with free tech support by way of on line instant messageing. They sell that flyback which is a part prone to failure. Its the only RCA flyback that they stock. Heres the link.
Apr 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
