BAD TRACK FOR EVERY SONG
Hi tooky.
Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info.
One solution would be to format your player in Windows Media Player (version 10 or 11):
1. Make sure your player is in MTP mode by navigating the menu as follows:
Menu > Settings > USB Mode
You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure".
2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt.
3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature.
You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts
Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well):
For standard E250 or E250R "Rhapsody Series":
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Make sure your player is set to MSC mode, or "Rhapsody" Mode
The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files.
I hope this helps. There are other procedures available but these might actually make your player work normally again.
Hoping for the best :)
my songs that go into untitled are labled with the titles of some of my songs and then when i go 2 taylor swift come in with the rain
it plays little big town im with the bad and then when i hit another song it says bad track and then freezez and none of my buttons work
ps . never get Mary lynn rajskub
she plays chloe obryan in 24
i own every season and i cant wait until season 7
mary s song is the 1 that frezez and the 2 min later it says bad track
I transfer songs from my computer to my sandisk and when I try to play the songs, it says bad track and won't play a lot of the songs. But now when I hook it upto my computer it says that it cannot connect and does not recognize the device.
