I need 3 heads for my tape deck
Can you inform me where can i get them, and if so, how much....please.
Thank you for helping me solving my tape deck problem. Parts are to expensif and i decided to put it in the trash. 3 heads at $ 79.00 each plus shipping and handling and money exchange...
Merci beaucoup... Denis Denman . Montréal Québec
Posted on Dec 05, 2008
Sony SPZ70 Cassette deck
If the reels are going to quick it is either in fast wind or the pinch roller and head base are not moving up. Try again and if still no result tthen a Technician needs to see it.
Aug 12, 2013 | Sony Audio Players & Recorders
I WANT TO PURCHASE ONLY CASSETTE TAPE DECK HEAD ; AMORPHOUS Z 3 HEAD FOR TECHNICS CASSETTE TAPE DECK
All you can do is look on E bay for someone who is selling such an item. The fact that they are no longer produced is going to make the price high. This is the reality of cassette tape decks these days.
Oct 02, 2012 | Audio Players & Recorders
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
I don't have the manual. I placed a tape in the deck and cannot remove it. Help!!! It has happened before, and suddenly I will be able to remove it, and then it will happen again. I'm not...
pry on the tape deck cover with a thin knife and see if it opens...what happen is that your tape deck eat up the tape with the spindle this is due to the fact that the head and the spindle and the pinch roller is dirty.to clean these parts trick the deck as if it has in a tape.do this by when you open the cover push down the lever at the bottom of the tape rest in the tape deck when you have remove your tape. at the same time press play it will start to spin take a cotton swab dip into alcohol press it on the pinch roller until it is clean also apply it to the head. after cleaning you are good to go your tape will stop stuck until the head and pinch roller gets dirty again. good luck.
Sep 23, 2011 | RCA RS2610 CD Shelf System
In both tape decks music only plays in one channel. How can I fix this?
This can be due to one of the following reasons.:
1.The head can be dirty, use a head cleaner to wipe off dirt from the head.
2. The connections to the head could have come off. check on the head connection.
3. The head can be faulty.
4. The preamp or the power amplifier of one channel can be faulty. you need to use a signal check to find and confirm.
Mar 24, 2011 | Sony TC-WE475 Single Cassette Deck
Wr565 - both decks jam the tape when i play them. any suggestions?
rss13506,
I'm not sure what you mean by jam but I bet you need to clean the head, roller and pin in each deck. Use rubbing alcohol and a q-tip to clean the:
1) Head (silver thing in the center bottom where the tape slides over; it produces the sound).
2) Roller (black wheel thing that keeps tension on the tape).
3) Pin (above the roller-works with the roller).
If any of these parts are dirty the deck will eat up the tapes. Clean them even if you do not see visible dirt on the q-tip as dust does not show as well as oils in the air typically from cooking will gum up the parts. Give them ample time to dry before trying a tape.
As any tape playing person knows from the 70's and 80's-try a tape you don't care about first, to make sure the deck will not eat up the ones you like!
-Chris
Sep 06, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Goodluck..
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
70 people viewed this question
 Grubhead
Grubhead
