Question about Sharp 32C-240 32" TV
Volume on tv set not right
I have one cable box,and two tv's.I don't get all the channels unless the cable box is hooked up so i hooked it up to the telivision in my bedroom when i went to bed.The volume was loud when I turned it on so I turned it down.The next day I unhooked it and hooked the cablebox back to the tv in the living room.When I went to bed that evening I turned on the television and there was no sound at all so I pushed the volume button and instead of it going up one notch at a time it instantly jumped to the halfway mark then when you depress it again it goes to the highest mark.How do I correct this?
    President:
  • 1,284 Answers
Try unplugging the TV for 2 minutes then try again.
Posted on Feb 09, 2007
SOURCE:
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
I bought my 2yr old son a daewoo vcr combo tv model # dvq13h1fc and it didn't come with a remote. It does not have a menu button on the tv, so im trying to figure out how I can hook his dvd player up so he...
Many combo tvs are simplified so as to play its own dvds or in this case its own vhs tapes. Never purchase a combo unit unless you wish it to be stand alone. Always look for how many plug-ins are on a tv before you purchase it. The number of plug-ins is a sure way of telling the quality of the tv or any other device. If all you have is a co-axial input then use that to send a signal from a dvd player that has a co-axial in and a co-axial out. Turn the tv to channel 3 to play through a dvd player. Use the remote control from the cable company to change channels on their box and change the volume manually unless you can find a setting for that to change the internal volume in the cable box.
Oct 15, 2013 | Televison & Video
Volume disappears on certain channels
if you get sound on some channels and not on others it's
not your tv. do you have your cable box or what ever, hooked up to tv through a caoxal cable or through audio video jacks .some shows only have right or left audio not both if you use a coax from box to tv try av wires insted
Oct 01, 2013 | Sanyo Televison & Video
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
No sound on sony tv
Your set may have a choice of audio sources and outputs in the basic (initial) setup since it is not uncommon to mute the internal speakers and get your sound from a home theatre system or receiver. Also, if you are using S-video connectors between converter and set, there is no sound path, this is video only, and you will have to add a couple of cables, likely with RCA connectors, between the two.
For reference: Audio cables: Red=right channel, White=left.
Sep 06, 2009 | Insignia Digital-to-Analog Converter for...
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Sharp 32C-240 32" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
