Layed heating mat then tiled no continuity need to trace where break is to rectify
  • 706 Answers
Hello pamandb,
You may not have continuity thru a heating element but you should have some low resistance. If you've got an open in the el;ement itself, then you may have to remove the time to get at it to repair or replace. I have use signal tracers ( generate a sgnal in a wire and can be tracked with a receiver wand ) to track wiring and they cost about $50 - $70 in stores like home depot.. but regardless of where the break is, in order to repair it, you wil have to gain access to it which means removing tile.. Good luck
Regards,
Rick
Posted on Dec 04, 2008
Instructions for beginner bathroom tiling
id watch some you tube videos
Dec 02, 2017 | Home
Tip
Ceramic tile installation
To Start a Ceramic Tile Project:
1st: Figure out the Size of the Room-Length x Width. This will give you the suare Footage of the Room, and will Determine the amount of Materials You will need for Preparation of Floor before Tile Installation.
2nd: Pick out the size of Tiles, and the Color you wish to Purchase(Decide if it is a High Traffic Area) Tile Comes in different Grades, and if a High Traffic area, you will need a Higher Grade Tile.
3rd: Materials needed for Preparation- Hardy Backer Board(1/2"-3' x 5'). HardyBoard Screws, Unsanded Mastec, Spacers-Depending on Tile Spacing/size of Tiles, 1' x 4' boards. (Tools Needed- Drill, Chalkline, Measuring tape, 3/16 x 3/16 Trowel, 1/4 x 1/4 trowel).
Installation; )Preparation) 1- Apply a 3/16 x3/16 trowel of Unsanded mastecon floor before laying the Backerboard. Screw the Backer Board to the floor recessing screws. (Never have Backerboard meet with 4 pices meet together, off set each piece of backerboard during Installation). After sweeping the room, use a trowel to fill screw holes with unsanded Mastec. Tape all Joints and fill with un-sanded Mastec.(Let Dry for 24 hours).
Tile Installation:- 1st- Sand Mastec used for joints, and screw holes. 2nd- Sweep roome very good and vacuum very well. 3rd- Measure each wall to find the Center Point of the room.(I prefer nailing a board down across one side of the line to keep tiles straight, and butt tiles to the board, and put spacers in between tiles). I use a 1/4" trowel to butter tiles before laying. With using Spacers, buttering tiles, laying tiles.( I prefer using a 2 x 4 and tap tiles across with a rubber Mallet to keep all tiles same heigth). Let One side tiles laid for 24 hours. 4th- Then do the same thing with other side of line.
Finishing Project: Once all the tiles are set, and all spacers removed. Mix up color of Choice unsanded Grout, and follow Manufacturers mixture Specs. Use grout Float and fill Spacing between Tiles. Let dry for 15 minutes. Use bucket of Clean water and Big sponge rinsing frequently removing all Grout from Tiles. Let dry for 30 minutes, and clean tiles again with Clean Water. Let set overnight. Next day, take Clean towel and rub haze off the tiles. Lastly, Seal Tile and grout.
Enjoy your project, and the Satisfaction of doing it yourself. Hope i was some help!!
on Feb 06, 2012 | Ridgid Saws
What tiles are used for living areas?
That totally depends upon your personal tastes, and whether your subfloor is strong enough to handle the movement. The larger the tile, the more solid your subfloor needs to be. Moreover, NEVER lay ceramic or stone over tongue and groove hardwood floors .. far too much flex .. and don't buy into the "well .. we lay fiber cement board .. " Fiber cement underlayment does NOT add to stability or structural integrity.
So, what type of tile do you want? Then, it's beefing up your subfloor .. to accommodate. Add underlayment, thinset and set .. grout the floor and you should be good to go.
Apr 04, 2017 | Saws
How do I break up old bath room tiles
The common method is to use a small electric demolition hammer, like this
http://toolguyd.com/blog/wp-content/uploads/2013/05/Bosch-DH507-Demolition-Hammer-Tile-Removal.jpg
They can be easily hired if you are in a city. You can get various points for it, from spear to wide chisel.
http://images.makita.co.nz/_productshots/accessory/B/bits-chisel-M.jpg
If laying more tiles after, keep the undersurface as level as you can. Wear ear and eye protection. If your hands start to tingle while using the hammer, take a break.
There is a machine the pros use too, a power scraper
http://img.diynetwork.com/DIY/2003/09/18/adi609_3fe_lead.jpg
Jun 24, 2016 | Saws
Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
May 16, 2013 | Home
What can I use a foam floor mats for?
Foam floor mats can be effective as door mats for tents to keep some of the dirt and sand out. Furthermore, foam floor mats have other uses include padding under iceboxes in vehicles and boats and they also make ideal padding for protecting loads when travelling.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
How to lower the blade it's not cutting all the way thru..stand. 12 inch tile..help please
a temp fix,put a thin rubber mat under your tile.my bridge saw does plunge cuts & has a knob on side of cutting head, your blade must have been changed somewhere even if changed with the same size blade some vary in overall size,good luck
Nov 05, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
How to heat gun
When you remove old carpet from a room, you will most likely be left with remnants of glued-down backing on the floor. Getting the tile back to it's original smooth appearance can be a tedious task. You will need to make sure that you have a lot of patience and a lot of elbow grease. Start removing the glue by scraping the tile with a heavy-duty wallpaper scraper or a long-handled scraper. Do a quick sweep of the floor. Plug in your heat gun. Once it is heated up, you will want to place it at a forty-five degree angle to the floor and direct the heat on the remaining carpet backing. The carpet backing will loosen considerably as the glue begins to dissolve. The carpet backing will loosen considerably as the glue begins to dissolve. Use the wallpaper scraper to remove the loosened backing. Work in small sections. Once you have removed the carpet backing from the tile, wash the area with warm water and soap to ensure all of the glue and backing are removed. Continue until the entire tile floor is free of carpet backing.
Aug 27, 2008 | B O X Packaging Two Temperature Heat Gun
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
