Question about Sanyo DP32746 32 in. LCD Television
When I hook up my satelite box using the blue/red and green cords the picture on the screen in pink and there is no sound. What do yo think the problem is I have tried a 2 different cords that are both brand new and the one ahs never been used.
  • kklassen Dec 04, 2008
    If i switch the blue and green i get no picture but if i switch the red and blue the screen turn blue.
    yuppers that worked, don't know why I didn't think of it cause I should have. I feel like an idoit.
  • 51 Answers
What happens when you swap a blue and green on one end?
Posted on Dec 04, 2008
  • Paul Hertel
    Paul Hertel Dec 04, 2008
    get into the menu on the satellite tuner and make sure that output is set to be component and not Y/C or CVID
  • Paul Hertel
    I step on my own tail every day.
    Sometimes a second set of "eyes" is all it takes. ;0)
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
I hooked up my Vizio LED LCD to my Philips surround sound and my DVD picture is pink. What do I do?
This sounds like a problem with the component video connection (the red/green/blue cable; sometimes labeled Y,Pb,Pr). You can get a pink screen if the Green (Y) or the Blue (Pb) aren't plugged in correctly. Recheck those first.
Mar 01, 2011 | Philips CCC130AT 13 in. TV/VCR Combo
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
How to hook up TV with set top Cable box
If you have a new HD cable box then I would use the RGB cables. It is a 5 cable cord with color codes of RED-GREEN-BLUE and a Red/White for audio. They will go from the output of the cable box to COMPONENT INPUT on the back of the set along with the audio in. This will give you the best possible picture and sound.
Nov 26, 2010 | Vizio VA26L 26 in. LCD HDTV
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
How do i hook up the speakers?
If your sound card has only pink, green and blue colors connectors in this case you will connect your speaker’s green cable into the green connector of the sound card. (Orange and black connectors will not be connected)
You will connect your microphone (if you have) to the pink connector of your sound card.
Please find the pictures which explain the color codes below:
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Logitech X-530 Computer Speakers
I tried to hook up my dvd player and i get picture but no sound. when i put the cords in the back of the monitor there is yellow red blue green holes no white spot. Do i need different cords. I have tried...
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Feb 23, 2010 | Computers & Internet
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Dvd screen is pink
If you are using component cables to connect the DVD to the tv make sure you have the red,blue and green colors on your cables matching these colored jacks on the tv and DVD jacks. If one of these cables is plugged in wrong or not plugged in it could cause this. Good Luck
Jan 04, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sanyo DP32746 32 in. LCD Television Logo
50 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
