Turning on shuts off red light starts blinking
When i turn tv on it goes right back out. then the red light starts blinking continously.
  • Anonymous Dec 17, 2008
    red light blinks on and off. Power will not come on. 32HFX71
  • 790 Answers
You have defective Oscillation Circuit maybe you have leak small parts like capacitors and resistors. and also the HOT Area.
Posted on Dec 05, 2008
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
No Audio & Video red light blink continously.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
May 29, 2009 | Sony KP-57XBR10 57" Rear Projection...
My ps3 has started to crackle then the picture goes and then comes back this is continous no problem with the tv as this works fine?
Sounds like your PS3's GPU may need to be reflowed. This is caused from a overheating problem with many of the PS3's you will eventually get a blinking red light and the PS3 will not turn on.
May 17, 2009 | Sony Playstation 3 (PS3) Console
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
