Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Power cord replacement
I have a February 2004 model with the cord cut off. Do I need to do anything out of the ordinary to slice a new cord on to see if this TV works? Any recommendations on how to best replace the cord?
    President:
  • 1,284 Answers
You must make sure the wiring is correct no matter what you do as the TV has a polorized cord (one blade larger than the other). It is a saftey feature and must be used.
Posted on Feb 09, 2007
I need to replace the power cord on a Dualit 4 slice toaster model 40418, where can I buy this ?
This an ordinary cable that you can from electrician shop or DIY shop nothing specal. Just cut a piece so hey will give you the same size
Jul 23, 2011 | Dualit 20247 2-Slice Toaster
How do I put a light switch on a extetion cord
You want a light switch on extension cord.
What kind of light switch do you have? You posted under GFCI device which is totally different than ordinary wall switch.
And what type of extension cord?
Add a comment with more information.
If ordinary light switch is installed on 3-wire outdoor extension cord:
Slice open the side of cord and you see 3 wires: black, white and green.
Cut the black wire in half and connect each end to brass screw on light switch.
If ordinary light switch is install on indoor 2-wire extension cord.
Look at plug and notice there is a wide blade and narrow blade.
Narrow blade is hot. You want the wire connected to narrow blade.
Cut that wire in half, but do not cut other wire.
Connect each end of wire to brass screw on light switch
If you want to install line switch onto indoor 2-wire extension cord:
Narrow blade is connected to hot wire.
Open line switch.
Connect each end of black wire to brass screw. OR if no screws, then place cut wire in open grooves.
Tuck other wire into groove and then reassemble switch.
Jul 05, 2011 | Leviton 8299 Combination Switch / Smart...
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Need to replace the battery in a 2004 lincoln aviator is there anything out of the ordinary? will things need to be reset?
yes best if you can hook up jumper cables to your vehicle so you dont lose power to your internal componants
Dec 16, 2009 | 2004 Lincoln Navigator
I am looking for a replacement cord
Buy or get an extension cord of at least equal thickness. Cut the receptacle end off. Attach (twist the wires together and solder) the extension cord to the old wires.
Sep 20, 2009 | Viking VT400BR 4-Slice Toaster
Dog chewed the electric plug
Your local appliance shop should be able to hook you up with a replacement cord. Slicing another cord onto the existing cord would nullify the UL listing for the appliance, void your homeowners policy, and would probably put you in line for a Darwin Award. In addition, beating a poor dumb animal with a power cord like the other guy suggested is just plain cruel.
Jul 14, 2009 | George Foreman GGR62 Grill
How to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
May 03, 2009 | Televison & Video
Need a power cord for a Zenith L20V26C 20.1 in. LCD Television
You can find a replacement power cord for this model from a major Zenith/LG parts distributor at the following link:
Zenith/LG L20V26C Replacement Part Power Cord
Please note the AC Adapter is no longer available from the manufacturer as you can see here.
Jan 29, 2009 | Zenith L20V26C 20.1 in. LCD Television
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
