Question about LG Dryers
I have new DLG1320w gas dyer and do i have to buy the sepcial gas flex for it
  • 706 Answers
Hello rubendidit,
Many home improvemnt stores such as home depot and lowes carry flex gas lines and shutoffs for these applications.. Some states require the gas line to be hard plumbed in so check applicable laws and use your own judgement. If you decide to go flex ( they are usually yellow colored) you may also consider picking up some 'snoop' leak checker ( sudsy water based product you daub onto fittings to make sure you don't have any gas leaks.. You put it on fittings and watch for bubbles.. if you get bubbles.. shut off the gas and repair the fitting with proper thread sealant.. Good Luck
Regards,
Rick
Posted on Dec 04, 2008
Where is the reset on a LG dryer model #DLG1320w
There is no "reset" on the unit. What is the problem you are having?
Apr 17, 2012 | LG DLE0332 Gas Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Gas dyer not heating up
Most of the gas dryers have everything accessible by simply releasing the spring clips atop the toe panel and getting it out the way.
Here are some repair pix with manual
Sep 05, 2009 | Kenmore 63942 Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Gas dryer problem
I am getting water in my vent hose. What could cause this.
Dec 13, 2008 | Roper RGX4634KQ Gas Dryer
Kenmore Model 97310100
Are the coils getting voltage do you know? Or you can check the thermal fuse to see if its open.
Oct 23, 2008 | Kenmore 62602 Electric Dryer
PRG3610NP
when you buy a new stove the manufacture installs a small cap on the stove side i know its silly you probably removed that part before you installed the flex line just check that if you did already well then i,m stump-ted thanks the appliance doc
Sep 22, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
155 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
