HP HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Problem for HP HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel...
WLAN not working on my hp Pavilion dv2000
By unchained_fr on Dec 04, 2008
I have an HP Pavilion dv2000 that used to work perfectly, especially with the wireless internet, by a switch in the front of the machine.
I woke up one day and I tried to hop online, but all that was available was Bluetooth and WLAN was no longer an option. Anytime i tried to search for networks to hop on, there were none available, when there were always networks available before. I checked the drivers, uninstalled and reinstalled them, went into the BIOS to enable the Internal Network Adapter, but nothing is working. Plus, i am not covered by the Extended Service Plan offered by HP for Laptop repairs.
I think i may be missing something very minor here, but i am at a loss for what to do. could you please help me?
Same Problem
Nov 05, 2009
-   My brother just gave me his HP dv2000. Same issue. Was informed by HP it was a bad motherboard. Of course right after warranty expired. Go figure. It works sometimes but I just plug an Ethernet line in at home and it works fine. Besides, it was free...-   nspimt
Apr 05, 2009
-   WLAN not working on properly -   Guest
Jan 24, 2009
-   same thing -   Guest
Jan 02, 2009
-   I have the same problem. Only to start Wifi I must restart Wireless Zero every time I boot up--it does not start up even though it is set for automatic startup, and next I need to go to change advanced settings and then to the irelss Networks Tab and check Use Windows to configure my wireless network settings.  I suspect there is another HP service that is disabling the Windows Wireless Zero configuration and this checkbox.  I'm still working on a solution.  -   Guest
Solution #1
posted on Dec 04, 2008
Somewhat Helpful)
tanvierahmed
Rank: Wiz
Rating: 84%, 53 votes
There is a service called Wireless Zero Configuration.
Restart this service.....
Windows Vista
To start Wireless Zero Configuration in Windows Vista you need to log in as an Administrator.
  • Click onStartandControl Panel
  • SelectAdministrative Toolsand thenServices
  • In theServicesbox scroll down the list ofServices (Local)until you find the one labelledWired AutoConfigand double click it.
  • In theWired AutoConfig Properties (Local Computer)box change theStartup typetoAutomatic
  • Click onStartand once the service has started click onOK
  • Now find the service labelledWLAN AutoConfigand double click it.
  • In theWLAN AutoConfig Properties (Local Computer)box change theStartup typetoAutomatic
  • Go toFileandExitto close theServiceswindow
Windows XP
Windows XP users must have Service Pack 2 installed to activate the Wireless Zero Configuration. (How do I check that?)
  • Go toStartandControl Panel
  • Click onAdministrative ToolsandServices
  • In theServicesbox scroll down the list ofServices (Local)until you find the one labelledWireless Zero Configurationand double click it.
  • In theWireless Zero Configuration Properties (Local Computer)box change theStartup typetoAutomatic
  • Now find the service labelledWLAN AutoConfigand double click on it
Let me know if the problem is solve...
rate me if you think it helps you..
best regards
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 21, 2009
Not Rated)
nspimt11
Rank: Apprentice
Rating: 0%, 0 votes
nspimt here again,
After messing with this WLAN issue on my free HP dv2410us and reading many sites, the easiest way to connect to any net is simply use USB Wireless device. The Laptop should not have any problem identifying it and it works well. I suggest using the extension cord that comes with most USB adapters. You can move it around to get better signal strength. I also find that by disabling the WLAN, restart, then shut down for about 5 or 10 miuntes, then start and PRAY it loads the Broadband/WLAN Driver. If it loads and works, enjoy and leave it running more than shutting it down. If you hve OCD like I do, lol, it will bother you that it doesn't work but just plug the USB-G in and you will be okay.
My brother spent some bucks on this Laptop from HP and right after the Warranty was done the Motherboard went bad. HP has identified this problem but really does not do a good job of standing behind the product. With todays economic condition, I'd think $ about that. Money talks and Bulls*** walks.
Was this helpful?
Yes
No
Solution #3
posted on Oct 21, 2009
Not Rated)
martyj160
Rank: Apprentice
Rating: 0%, 0 votes
I was ahving the same problem with my HP Pavilion ze2000 and it solved the probelm. !! Thanks A LOT
Was this helpful?
Yes
No
Popular Solutions for HP HP Pavilion dv2000t 14.1"
Questions and Unsolved Problems for HP HP Pavilion dv2000t 14.1"
Do you recommend HP HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook?
Answer
Answer
sometimes does not power on. no sounds no image. but sometimes can be turned on normally.
Answer
my screen keeps flickering with mobile pc presentation setting keep coming on even though there is... (More)
Answer
HP dv2000-built in webcam displays black,lights on.---i need help on this.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
