Question about Maytag CWG3100A Gas Single Oven
Wall Oven I have a wall oven that needs replacement. It is 24" wide. The cabnet from front to back measures 19 in. Will a oven with 21 in depth fit in to opening?
  • 706 Answers
Hello zultar777,
The oven will fit however it will stick out a few inches beyond the front of the cabinet. If that looks ok to you, then go for it.... Is ther any way you can open up the wall behind the oven to allow the new oven to recess in deeper? You may want to investiaget that option. If the wall behind the stove is a non- weight bearing wall..you should be able to cut it opne and remove a section of the wall studs.. also..check to see if the new oven uses any mounting tabs to lock it in place.. if it does and these are close to the front of the oven, you may have to jury rig something to secure the oven.. It may or may not use them thou so check with the manufacturer..
Good Luck
Regards,
Rick
Posted on Dec 04, 2008
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
Will a GE built in oven JT3000DF fit in the space that has a Kenmoore build oven in that space at this time 9114105559 part number
Simple. Measurements. Unless i'm missing something here.
Take present oven detailed measurement, compare it to the newer oven's detailed measurement.
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
I have a GE wall oven, model # JKP07G004B0 and I would like to replace it. I need to know which new one will fit the space.
Since it is so old the diminsions are no longer available online and the only way to get the size is pull it out 4-6 inches and measure height,width and depth of the cut out portion of the cabinet it fits into
GENE
Jul 30, 2011 | GE Ovens
Hi We need to replace wall oven model 755T what size wound it be so we can buy new one Thanks Tracy
The best way to determine the size wall oven that will fit is to partially pull out the existing one and measure the cut out of the cabinet it will fit into
Jul 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
We have a Frigidaire Wall Oven that shows Err F3 - no buttons work. Model FSC88B-4 . The Oven temperature sensor measures at 1089 Ohms. There is 5 VDC on the control board. Tried resetting by removing the...
The sensor checks good. The only thing left to check the wiring between the control and the sensor. Check this for opens and shorts. If all checks good you will need to replace the EOC electronis oven control / clock. You can get diagrams and illustrations at www.appliancehelponline.com by entering your model #. All parts come with installation instructions.
Apr 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Sep 01, 2009 | Frigidaire 24" Single Gas Wall Oven with...
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Maytag CWG3100A Gas Single Oven Logo
177 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
