Question about Euro-Pro EP278 Bravetti Platinum 1500 Watts Toaster Oven with Convection Cooking
Help - eurovox download
Hi Steve
Thks for your advice. As I am not that good with all the techno stuff, could you possibly give us step by step.
Many thanks
Deb1pat
    Problem Solver:
  • 12 Answers
Not sure what advice i have given. whats the make of your box. You need to download the bigmaq toolbar first and install it.. there are fixes for all makes of boxes , i can only tell you about eurovox as i have updated mine let me know if you have eurovox if it is eurovox download the au fix for your box the one dated 30 11 08 then you connect your box to pc using 9 pin nullsoft modem cable must be same both ends (usb one won't work) once you have connected box to pc make sure the eurovox is turned on, open the fix you have downloaded looks like tv and a box next to it just click on that that will open box click the download button then click start.this takes about 80 secs your eurovox should have dwld on panel while this happens. once thats done you need to go into your setup and clear all data that just deletes any channels that were there before then run powerscan once thats done your box will be up and running again sounds complicated but it's really easy
hope this helps steve
Posted on Dec 08, 2008
Tension spring on door
I found the answer (see below) posted on another web site. I followed the instructions and replaced the spring. I found, as the original poster had, that the new spring works better than the original and is much more sturdy. To the original instructions, I would add the following:
1) There are about 20 screws so have patience removing and replacing the screws.
2) Step 3, "Slide off the rear panel" requires further clarification as the panel will not slide off even with all screws removed. I had to turn the oven over, with the top of the oven sitting on the work table. I then used a screw driver to lift the two tabs that hold the back panel to the bottom panel. With the tabs lifted, the back panel will rotate away from the oven along the edge where back panel slides into the top panel. The back panel can then be slid out. I have included three photos that show this step.
3) Step 7, "Re-attach feet": Be sure to use the guides on the bottom of the oven to slide the foot assembly onto the oven. I had unsuccessfully tried to screw the feet onto the oven without using the guides.
Oringinal instructions for replacing the broken spring:
Just repaired this yesterday.
Got a spring from Lowes (Hillman Part # 543028 for about $4), it's larger than the original but seems much sturdier, original is really thin metal. Fit the space provided without problem.
Oddly, end result was a more 'giving' spring action, prefer it to original, which loved to snap shut unless door was 100% opened (ie fully 90 degree open).
This is for BOV800XL:
1. Remove all rear screws
2. Remove feet entirely
3. Slide off rear panel
4. I was not able to remove top housing - but I was able to gently pry sides open just enough to thread the new spring with a little ingenuity and effort. Watch out for sharp metal edges everywhere.
5. Slide back in (remember that top edge goes under the top edge/lip)
6. Put all screws back in
7. Re-attach feet
7a505b80-f785-4973-b674-12594d9dcb1d.jpg 2e67ee3d-99c9-4e88-8b9f-8d1721e5caa6.jpg 529808f4-8d72-4aea-8286-b525347addee.jpg
Apr 02, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
I need the Easy Installation Step-by-step mounting instructions and Pre-sized mounting template for Black & Decker TROS1000 SpaceMaker Digital Toaster Oven. Thanks
For a manual you can go to blackanddeckerappliances.com. Then under the Customer Care tab click manual and follow with info needed for your SpaceMaker. That won't give you the template so try the phone numbers here for Black and Decker to ask them.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
1-800-231-9786 Monday - Friday 8:30 AM - 8:00 PM ET
Mar 25, 2011 | Applica TROS1000 Toaster Oven
Have wrtten a question but why should I be stupid to pay for a simple answer. Forget it!!!! A simpel question should be a free service!! Lars Nyman
Hi, Lars, W/D here.
Sorry that this appeared offensive to you. Take another look!
When you come to FixYa, you have several options. The first is to post your question and people familiar with your issue give you repair options for free. If you don't want to wait, and wish to go directly to one-on-one chatting for a fee, you can do that too.
You don't have to pay anything to post a question here, and you'll get a good many answers from experienced people who are just trying to help people like yourself repair the things that they can fix without the cost of a service call. Pretty good deal, huh? Anyway, you've misunderstood how this works. Give it another try, and I think that not only will you be back, but you may find yourself willing to help others by sharing the things that you know how to do. Great Karma.
Best regards,
--W/D--
Jan 22, 2011 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
One of my GE toaster oven's 2 top elements burned out
Hello. It is very difficult finding parts for and appliance over ten years old. I recommend that you shop a bit for a new toaster oven. They are much less costly than they used to be and work better. Plus they have a warranty. J.
Jul 21, 2010 | GE Toaster Ovens
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Shark jet oven Euro ProX Manual
OK, go to http://www.euro-pro.com/europro/faqdetail.aspx?modelno=to160l for model TO160L toaster oven or, if that is not the model number of your oven, enter model number (should be on the back plate of your oven: turn it around) into the box at the top left of the screen displayed when you use the address listed above. Good luck! alex bau.
Aug 11, 2008 | Euro-Pro TO285 1500 Watts Toaster Oven...
Panasonic Infrared Bulb Replacement
Ordered a Heater, part #ABA83-148-0U from www.partstore.com - per the advice on this website.
May 09, 2008 | Panasonic NB-G100P 1300 Watts Toaster Oven...
u can download manual i came across it by accident go to google put in shark jet oven and go where they sell it it has adown load manual at bottom of page
cheers Mary
Dec 06, 2007 | Euro-Pro K4245 Toaster Oven with...
Infrared bulbs Panasonic NB-G100P
Many parts are available from Panasonic's website for this model. Do a search for NB-G100P then click the displayed link. from that page, you should see a link at the bottom of the page for parts.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Kitchen-Appliances/Toaster-Ovens/model.NB-G100P
Stan
Nov 04, 2007 | Panasonic NB-G100P 1300 Watts Toaster Oven...
Euro-Pro EP278 Bravetti Platinum 1500 Watts Toaster Oven with Convection Cooking Logo
111 people viewed this question
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
