Question about U-Line Icemaker
I just installed a new ice maker in my Frigidaire freezer model # FRS23KF7AWO. Is there a trick to getting it started??
  • 706 Answers
As long as you have water turned on and power to the ice maker.. it should go thru its normal cycling process and begin to work overnight.. some take at least 10-12 hours to fill the water lines before that water is presented to the ice maker itself and ice is made.. Hope that helps
Regards,
Rick
Posted on Dec 04, 2008
How can I get rid of those nasty little floater in my ice?
Replace your ice maker. Your ice maker mold is flaking and collects into the ice. Good Luck
Aug 12, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
We are replacing the ice maker. we have installed the new one and it is not working. the water is not going up to the freezer. we have made sure all the line are new and are clear.
Did you replace the water valve as well? How long ago did you install the ice maker? Remember the ice maker needs to be pretty close to 0 degrees before it will advance and call for water the first time.
Jun 11, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Feezer does not make ice. there is cold water. Installed new filter
Check the temp inside the freezer with a thermometer. It should be between -10 and 0 degrees. The ice maker has a thermostat that cuts it off once the temp gets above 5 to 8 degrees. (According to the model) If your freezer is warm, check the inside back panel of the freezer. If it has ice or frost on it you have a defrost problem. This will have to be repaired before the ice maker will work. If you have ice or frost, your freezer will also continue to warm up until your fresh food section gets real warm.
Please rate solution
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
ICE MAKER.
ADJUSTING WATER FLOW WILL CHANGE THE ICE MAKING TIME UP. TO DO THIS PULL OFF COVER ON FRONT OF ICE MAKER AND ADJUST SCREW ACCORDENLING. HOPE THIS HELPS
Sep 25, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
U-Line Icemaker Logo
50 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
