Question about Campbell Hausfeld 28 - Gallon Air Compressor
Tool side has no pressure
My 28 gallon CH ironforce compressor has full air on the pressure side but no air on the tool side. Must have a valve stuck...which one. Need my compressor
  • ian stalker May 11, 2010
    are you saying that pressure is ok in the tank?
If there is sufficient air in the tank the regulator valve is either set to low or is stuck. if its stuck ur better off to buy a new one and replace the one u have.
Posted on Dec 11, 2008
I have a older model RMM 3 GALLON Air Compressor I need a pressure control switch do you happen to know where I could get one at and how much
these days you can buy universal 95 psi factory pre set
pressure switches from ebay US $28 up
3 gal tanks should handle that ok with its safety valve set
if lucky you may come across an adjustable pressure switch
Oct 27, 2016 | Air Tools & Compressors
I have a CH horizontal compressor. As the saying goes, leave good enough alone.....well one day I wanted to install an auto drain, so I cut the unloader tube, as instructed. After realizing the auto...
Don't know exactly why, but you have a restriction in the air outlet. Yes, it could be the regulator...or a kinked or defective air hose. Check the regulator...if you have previously removed it for proper direction of flow. There are small cast arrows on the regulator indicating proper air flow direction. Foriegn matter, dirt, or teflon tape may inhibit the flow at the regulator or a fitting. If the unloader tube was replaced as originally done I cannot think if how that could affect the you say the regulator is reading full pressure. And full pressure is getting to your is only the flow that is restricted. Take the regulator off the system to test your air flow and confirm a restriction at the regulator, if neccesary.
Oct 16, 2012 | Air Tools & Compressors
I have three nailers from CH and all of them sound like there is not enough pressure to fire the nail when i depress the trigger. i hear air escape, but it is at a reduced level compared to normal...
Check and adjust the air pressure at the compressor. All air tools have a recommended range of pressure, and you may not have enough air for the tool to work. Also, place two drops of pneumatic oil or light machine oil into the air inlet at the nailer, and then connect the hose. Fire the gun several times into scrap wood. Oil with 2 drops daily.
Best regards, --W/D--
Mar 06, 2011 | Campbell Hausfeld Air Brad...
Compressor initially starts up and fills tank to 120 psi with no problem. Compressor shuts off. When a tool is used the compressor tries to kick back on but hums and won't turn pump. If the "off"...
There is a small valve on the pressure switch that should relieve the pressure between the compressor and tank check valve. Make sure when pressure switch trips, it engages the relief valve and it bleeds the air out. Sometimes the valve itself comes loose and is not engaged by the lever in the pressure switch.
Oct 30, 2010 | Campbell Hausfeld 20 - Gallon Air...
Craftsman air compressor 2 hp 20 gallon, seems to running o.k. builds up to 100lbs shuts off when it hits 80lbs come back on, but when i run a tool , right around 90lbs the tool dies out and runs week.when...
IT depends on the tool. Some tools require higher cfm. (cubic feet per minute) of air. IF your air line is not large enough, then sometimes 90psi is not enough to operate a tool as there is a pressure drop at the tool. Look at the required cfm for each tool. Find a chart for air line size, cfm and pressure. Most impact wrenches should be used on a minimum 3/8" air hose. You could look at your manual and see what the max pressure is on your compressor. You may be able to decrease the differential pressure e.g off and 100 and on at 90, but then the compressor will cycle more frequently, and may exceed the duty rating of the compressor.
Oct 01, 2010 | Craftsman Air Tools & Compressors
I have a ch 28 gal (wl611700aj) air compressor,it pumps up to 80 psi.wont pump up any further but does keep running.whats your thoughts?
Here are a couple of things to check. While the compressor is running spray soapy water on all airlines, fittings, bottom of pressure switch, regulator and drain valve to make sure that they are not leaking. A small leak will prevent the unit from reaching cutout limit. Repair as needed. Next unplug compressor and remove cover to expose cylinder and piston. Move piston to top of cylinder and check for scratches or wear neer top of cylinder. If scratched, air is bypassing piston ring and will not reach cutout pressure. If cylinder looks good and no leaks then problem most likely is valve plate/ reed valves or head gasket. Problems within head will cause low pressure and air line to tank will be very hot. Bad reed valves will also cause air to blow out of intake when it reaches 75 to 80 psi. Parts are available at or at Good luck
Sep 11, 2010 | Campbell Hausfeld 26 - Gallon Air...
The compressor continues to run but no air enters the tire, the tire just seems to get more and more flat.
Hi, I suspect the plunger for the valve stem connector on the pressure head is not depressing the air release pin in the head of the valve stem.
I have a Black and Decker and have to use a valve stem seat removal tool to quicky unscrew about 3 to 4 turns the stem seal and then connect the air hose head. After the tire reaches the correct air pressure I have go thru the tighten the valve stem seat drill.
You can buy the vavle stem seat tool at any auto parts store. I keep mine with the compressor.
I don't want this to sound bad but... is the air hose supply vavle turned on? Some have a slider button on the valve you have to push to charge the hose. If the hose is charged then see above.
Thanks for using FixYa.
Feb 10, 2010 | Campbell Hausfeld 02-Gallon Air...
2-stage air compressor's recovery time takes twice as long
hi is your machine reaching full pressure? if so maybe your problem is with your tool?
Mar 23, 2009 | Air Tools & Compressors
28 gallon compressor....answer to your question about my problem
your regulator internal filter could well be blocked ,isuggest that you drain the tank fully and remove you regulator,check that tank is clear of rust or scale if all is clear then strip and clean your regulator
assembly or replace with new,problem should be gone all the best
this might be a silly question but the needle on your pressure guage couldnt be stuck?,have you drained your reciever?
Dec 06, 2008 | Air Tools & Compressors
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
135 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
