Question about KDS Valiant 6380iPTD-01 Notebook
Steering wheel needs to be centred 71 vg valiant
Need to get steering wheel off.
    Problem Solver:
  • 17 Answers
Is this a laptop question?
If this is related to an automobile, you do not remove the steering wheel to center it. A front end re-alignment is required to recenter the steering wheel.
Posted on Jul 21, 2009
I have a '64 Valiant, 225 slant 6, no power steering. When I'm on the freeway it's difficult to stay in a lane, like driving on ice. Air pressure is balanced. Any ideas ?
When you have front end problems like that it helps to underinflate the tires a little, so instead of the 32-35psi, try 28.
Note this is not a fix, just a band-aide to get you by untill you fix the problem.
These old Chryslers are great cars, but they do have front end issues. The front steering/suspension is pretty precise and way ahead of its time. When the parts wear out, watch out.
Inspect steering box, the play can be adjusted. Check tire rod ends, wheel bearings, control arm bushing, ball joints, pitman & idler arm.
Then have the alignment checked. Be sure your front tires match each other in size, brand, & tread. Be sure to run radials, bias-plys are known for their drifting.
The steering box play adjustment can be found at the following forum:
Slant Six Forum
Jul 15, 2014 | 1972 Plymouth Valiant
REPLACED STEERING GEAR BOX IN 2003 CADILLAC ESCALADE NOW WHEEL IS OFF CENTERED
IF you have a rack and pinion steering pull the steering shaft of the pinion splines and centre the wheels . Centre the wheel and put the steering shaft back on the splines. If it is master splined then centre the steering wheel and adjust each side tie rod until the wheels are centred . (one in -other out ). Remember that when the wheels are straight ahead then the steering wheel will be slightly to the left (USA) to compensate for the camber of the road.. IF a steering box pull the pitman arm off --centre the wheels and the steering wheel and refit the pitman arm
Mar 02, 2014 | Cadillac Cars & Trucks
How do i remove a freelander steering wheel
Ok, here it goes;
  1. Make SRS Airbag system safe, disconnect BOTH battery leads and wait 10mins for SRS battery to discharge.
  2. Remove two torx screws securing Airbag system (rear of steering wheel).
  3. Remove Airbag Module.
  4. Disconnect SRS connection.
  5. Disconnect steering wheel multiplug.
  6. Make steering wheel and front wheels central.
  7. Hold wheel and release/loosen big-fat-centre-nut.
  8. Pull wheel from splines.
  9. Remove and discard big-fat-centre-nut.
  10. Remove Steering Wheel.
Jan 29, 2013 | 2003 Land Rover Freelander
Steering wheel not centred when driving in straight ahead.
2 ways to resolve. Take steering wheel off and recenter on spline ( done by dealer or auto electrician due to air bag) , or do a wheel alignment adjusting tie rod ends same distance as each other ie move both wheels left to right or vice versa.
Aug 21, 2017 | Cars & Trucks
I need a new steering wheel for a BMW318ie LHD (1997)
disconnect neg battery lead, from underneath the steering wheel remove 2 torque screws and carefully remove airbag unit disconnect the 2 wires underneath it first, remove bottom steering column cover, next remove keys and allow steering lock to engage with the road wheels pointing straight ahead remove wheel centre stud, wriggle bump shake steering wheel till it slips of splines disconnect wires from underneath and remove wheel, installation is reverse, make sure you position steering wheel straight ahead, dont reconnect battery till airbag unit is reinstalled or you will get a warning light illuminating.
May 16, 2010 | 1997 BMW 318
How to pull steering column for blinker switch replacement
You will need some tools like a steering wheel puller and a few other tools. Take the cover off the steering wheel and the centre nut from the steering wheel. Use the remover to pull the steering wheel. Take the shroud off of the column and you will be able to see what is holding the switch onto the column. Remove the wiring harness and remove screws for the turn signal switch. There might be a star with a pin in the centre. Put the new switch on and put it all back together.
Sep 18, 2009 | 1991 Chevrolet S-10
Removal of airbag steering wheel on 1995 ford fairmont
has air bag gone off do you need to replace it with another airbag one if so disconnect battery and behind steering wheel there are star bolts take them out and pull centre of steering whee; off then undo nut in the centre but dont take nut right off give the back of the steering wheel a quick bang with your hand to free it then take the nut off
Aug 26, 2009 | Ford Fairmont Cars & Trucks
71 Super Beetle has the shakes
Have you rotated the tyres?have the shock aborbers been checked.Warped drums would show up in the wear pattern left inside the drum and on the shoes.You could take a wheel off spin the brake drum and with a felt pen slowly let the pens tip touch the edge of brake drum.hold pen in the same place without moving it and it will show up high and low sections if any.Are all the bushes(suspension in a servicable condition?Sounds like anti sway or stabiliser bushes may need looking at as your problem is when you accelerate,not so much pressure on the bushes,sometimes vibates and more vibration when you brake when its under a higher amount of stress.Could be a bent rim Could be need wheels balanced.Have you correctly adjusted your brake shoes?Therse a slot in the back of the wheel hub assembly
Oct 16, 2008 | Volkswagen Beetle Cars & Trucks
KDS Valiant 6380iPTD-01 Notebook Logo
82 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
