Question about Philips FWP900 System
Disc tray won't open
Working fine one day. the next day i can't get the disc tray to open.. the system powers up fine. i also can get the radio to work... just can't get the CD disc tray to open.. have disconnected/reconnected power supply... have hit it a couple times... still can't get it to open.. any suggestions are welcome. thanks.
Needs new tray drive belt
Posted on Mar 16, 2008
Open a paper clip and push one end into little hole next to disc tray. push hard, the tray will open.
Jul 19, 2012 | HP Pavilion a1640n (RC663AA) PC Desktop
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
Feb 10, 2012 | Microsoft Xbox 360 Console
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Feb 11, 2010 | JVC HX-D77 Shelf System
CD tray won't open and motor running
I know this is an old post but I saw it through google, because I had the same problem. I ended up tearing the CD door off and was able to look in and see that one of the cds was stuck. The player was trying to play disc 1 but had pulled disc 2 in under neith and it was stuck, causing the issue. As soon as I pulled disc 2 out the system works great.
Oct 07, 2006 | RCA RS2650 Shelf System
System unresponsive when modes are switched
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Apr 12, 2006 | JVC TH-A30 System
Philips FWP900 System Logo
416 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
