Di-524 to netopia 2210-02 wan drop
I have a remote network that I access via the internet from home. That network is a Bellsouth DSL one with a Netopia 2210-02 and a D-Link DI-524 coupled to connecto to remote sensors. Randomly the DI-524 looses WAN link via the 2210-02. When I am not there it means a dead system. When I am there it takes a reboot of the DI-524 to recover. Is there any way that I can get the DI-524 to re-establish the link after it has lost it without being there to fix it.
  • norm_roberts Dec 07, 2008
    The network already has sensors that FTP out to a website frequently. 2 of them every 20 seconds. So I don't think that inactivity is the problem.
    Master:
  • 409 Answers
Set a pc inside the network to issue a "ping" command to any website every 5 mins. that will keep the link alive. you can either write a script or use a program such as ws watch.
Posted on Dec 05, 2008
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Dlink DI524 wireless problem: cannot access the router
If the Router is new proceed to Step 1. If the Router is used power on and press and hold the Reset button for about 10 seconds. It is located next to where the power cord is plugged in. Use either a pen or paper clip to push reset button.
Step 1. Connect one end of an Ethernet cable to the Ethernet port located on the Cable / DSL modem and the other end to the WAN port on your D-Link DI524 wireless Router. The WAN LED light will illuminate to indicate proper connection.
Step 2. Connect one end of an Ethernet cable to LAN Port 1 on the back panel of the DI-524 and the other end to the network adapter in the computer you are using to
configure the DI-524. The LED light for LAN Port 1 illuminates to indicate proper
connection.
Step 3. Once all pieces ar connected. Open your Web browser and type http://192.168.0.1 into the URL address box then press ENTER. Once the log-on pop-up screen appears type admin for the user-name and leave the password blank then click ok.
Step 4. Once you have logged in, the Home screen will appear and you should see a box called RUN WIZARD in the middle of the screen. Click that box and follow the steps.
Setup Step 1 - Click Next
Setup Step 2 - Create Password and click Next
Setup Step 3 - Choose Time Zone and click Next
Setup Step 4 - Setup wizard will try to auto-detect your Internet connection type.
Setup Step 5 - Select your Internet Connection. You will be prompted to select the type of Internet connection for your router. More than likely it will be Dynamic IP Address. Click Next.
Setup Step 6 - Click the “Clone MAC Address” button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. Click Next.
Setup Step 7 - The default wireless settings for your 802.11g wireless network are: SSID = default Channel = 6. You can change the SSID name to whatever you like. This will be the name of your wireless network. Click Next.
Step 8 - If you wish to use encryption for your 802.11g network, the DI-524 is capable of two levels of wireless encryption - 64-bit and 128-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication. If you choose to use encryption, you will need to write down the encryption key so that you can connect your laptop or pc via wireless connection. Click Next
Setup Step 9 - Your is complete. Click Restart to save and reboot your router.
Setup Step 10 - Click Close to complete your setup.
Setup Step 11 - You will be returned to the Home tab. Close this window and wait for the Router to finish rebooting. Then relaunch your Web browser (i.e., Internet Explorer or Netscape Navigator), to link to your favorite Web site to test your Internet connection.
Here is the link to download all the necessary info to configure your router - http://www.dlink.com/products/?pid=DI-524&tab=1
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp://192.168.0.1 to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Name=VNC
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to http://10.0.57.46:5800
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the 194.145.183.83 is the IP address of your office, this should work. Be sure you apply a password or anyone going to http://10.0.57.46 will have access to you router, I also recommend changing the port from 80 to 8080 so that http://10.0.57.46:8080 has to be typed to access the remote management interface.
Jan 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Wan indicator does not light up..
Hi there
Getting Started
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
bellow:
Name field
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Mar 29, 2008 | D-Link DI-704P Router
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
398 people viewed this question
David Payne
David Payne
