Question about Philips Audio Players & Recorders
Connected Technics SL-D500 turntable to Philips FW-C550 mini shelf system using Aux. inputs on Philips FWC550 and could not get any sound from speakers when I set mini system to aux. setting. Did I miss anything?
  • 7 Answers
SOURCE: How to connect turntable Technics
Most recievers should have Phono Jacks labled on the back. That is where my Turntable an (MCS made by Technics but was sold under the J. C. Penneys name) connects on my JVC. I have 2 JVC 's One is old (1972) and one is new. Both of them have Phono jacks. Phono stands for Phonograph. This is an old term for turntables. The jacks should accept RCA patch cords. Good luck.
Posted on Apr 21, 2008
SOURCE: Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Posted on Jan 17, 2009
ButtFuzz
  • 463 Answers
SOURCE: Which port do I plug in MP3? aux or phono. This is
You'll want to use the AUX, because it, for sure, does not have any RIAA equalization, which the phono input may or may not have.
Short answer: Plug the mp3 player into the AUX inputs.
Posted on Mar 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Posted on Apr 06, 2009
  • 4234 Answers
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Posted on Apr 12, 2009
Kenwood turntable no sound?
Are you using a magnetic "PHONO" input on your amp/receiver, or just a line/aux input? The 'good' turntables from the 70's - 80's used magnetic catridges with a very low level output - you will need a phono preamp in order to hear the turntable. Only phonos (Crosly) that use ceramic catridges generate enough voltage without a preamp. Good luck and let me know if that answered your question.
Aug 10, 2014 | Technics SL-1210 Turntable
Connecting turntable to
The ones marked Phono or if you don't try Aux port
Feb 26, 2014 | Technics SCHD560 CD Shelf System
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
What do I need for my 1981 Technics turntable to play with an Onkyo TX-SR605
Hi, If your amp has no dedicated phono input you need to use a preamp to boost the turntable signal. You can then input via cd or aux input. styluscity@gmail.com
Oct 24, 2009 | Technics SL-1210 Turntable
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
No sound from my SCEH790 system from turntable...
Hi...
The aux wont work on a TT . You need a turntable pre-amp. Then you can plug it into the aux jacks.
Try partsexpress.com or mcmelectronics.com
Jan 11, 2009 | Technics SCEH790 CD Shelf System
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
** sound
First and foremost, make sure you plug into directly to the PHONO input of your receiver. If your unit does not have a PHONO input, then you wont be able to hear much coming from the unit. The PHONO input is a pre-amplified input, and this turntable requires an amplified input in order to transmit it's signal correctly. Just using an AUX or LINE IN will not have enough power to increase the signal of the turntable. You have the option of purchasing a PHONO PRE-AMPLIFIER (range in price from US$15-30), or purchasing a new receiver with a PHONO INPUT!
If you have it connected to your phono input, and still no sound, your turntable may have either faulty RCA cables (red/white cables), or a bad tonearm - in either case will need to be replaced.
Hope this helps.
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 09, 2008 | Technics SL-1200MK2 Turntable
162 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
