Question about JVC AV27F476 27" TV
Popping Sound I have a JVC AV-27F476 TV that works great but during use it has a very loud popping sound every once in a while. Is this a porblem with the TV or the Cable connection and should I look into returning or repairing the TV?
  • 1 more comment
  • Tim McCoy Feb 08, 2007
    The TV is not using any external audio equipment. I have a regular cable connected directly to the TV, a DVD player and a PS2 plugged in the video/audio in. Other than that there is nothing special plugged in (not even a cable box).
  • Tim McCoy Nov 09, 2007
    I have tried changing the cables and it still happens. I have recently had the input on auxillary with nothing plugged in so it was just a blue screen and it still popped. I noticed it might be happening more often. During normal TV use it will pop loudly, the sound will go out and then come right back to normal.
    I have tried every sound setting combination. Nothing seems to work.
    Problem Solver:
  • 10 Answers
Just try replacing the audio cables and your connections, or sound setting.
Posted on Feb 08, 2007
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
Popping sound
Check for any external shorting of the speaker wires. Check for kinks or cuts in the cable that feeds the speakers. Also check the posts or socket at the back of the speakers for damage or wiring shorting out. Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | JVC Mx-kc38 220w Compact Component Audio...
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Need JVC (I-Art) 32" Television Remote Control Code
ok that remonte control must to have autosearch code,on the manual of that remonte control you will find the instruction how to do that and the remonte will do the job for u
Dec 10, 2008 | JVC AV27F476 27" TV
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
Its the power cap mine did the same thing about 11 months into daily use
Oct 24, 2008 | JVC AV-32FA44 32" TV
Jvc AV-56wp30
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | JVC AV-56WP30 56" Rear Projection...
No picture, No sound
Hi there!
If the set is dead after the popping sound, then it has probably blown a component due to high voltage. Everything inside a tv starts with the power supply. Nothing will work unless the power supply is 100%. I don't know what your rates for repairs are in general, but the price sounds good. The final decision is yours to repair or replace. Good Luck, JUS004
Jan 24, 2008 | JVC AV-32FA44 32" TV
JVC AV-27F476 channeling the radio!
Please try to change the vco adjustment position or try to do fine tuning with the service menu.
Dec 28, 2007 | JVC AV27F476 27" TV
Power-on problem
yes..jvc has an upgrade for the crt driver ic's replace all three chips and resistors note: resistors must be replace at time chips are replaced now call a local tv guy you know the fix!
Aug 21, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV27F476 27" TV Logo
176 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
