Question about MSI K8MM-V Motherboard
Installing XP on HP m8120n
I wan to get rid of Vista on this machine. I get blue screen while installing XP. It has SATA hard disk. XP does not come with SATA Driver. I used nLite to add SATA Driver on XP Bootable disk. Still blue screen. probably SATA driver is not good or not recongnized. Thinking to use floppy disk and F6 to install driver from Floppy. But before I buy the Floppy drive I want to find out if there is anything else I can try.
    Scholar:
  • 134 Answers
The Blue Screen of Death (also known as a stop error, BSOD, bluescreen, or Blue Screen of Doom) is an error screen displayed by some operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down, to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
I hope it helps!!!
Posted on Dec 05, 2008
  • Fernando Cruz
    Fernando Cruz Dec 05, 2008
    Try to check all the hardware connected on your motherboard specially the memory...
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
Hi, While I was installing windows xp does not recognize hard disk blue screen appears. Do I need to set sata drivers before installing? Thanks
Hello
You need to install sata hard disk drivers during xp installation, otherwise windows vista or windows 7 will not required drivers during installation.
God Luck, and do rate the solution if got help
Dec 25, 2010 | Gigabyte GA-G41M-Combo Motherboard
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
Blue screen
If  you are trying to install Windows XP in latest Notebook, it will not be able to detect the Hard Drive since all the latest Notebooks are shipped with SATA Hard Drives and by default and Windows XP will not be able to detect SATA Hard Drives by default.
If you are having a Intel based Notebook, you need to download the SATA Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36132.exe
Find the instructions to create a bootable XP Disk using the SATA Drivers from the link below :
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps...
Mar 07, 2009 | HP Pavilion dv6000z Notebook
Install Vista on cq40-144tu
Take out the hard disk put it on the externaslcase hard disk and format the disk wipe all data from it , and chek the bios seting, put the bios on default seting than you will be able to instal wich OS you want. chek if you have enogh ram for vista , if no put XP not vista. wen you will have more than 1GB  put vista.
Jan 20, 2009 | Compaq Presario Notebook
Failed vista uninstall
do install the vista only, coz xp could not recognize the sata hd, it gives the blue screen error, if u want to install xp otherwise, install sata divers from the supplied disk with computer.
Nov 21, 2008 | Acer Aspire 5920-6727 Notebook
Getting rid of Vista on an HP G7000 Notebook PC
Go into the Bios and turn the Sata enhancement feature to disabled, that worked for me.
Aug 24, 2008 | Computers & Internet
MSI K8MM-V Motherboard Logo
502 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
