My mikomi 1GB usb drive keeps on saying the drive is write protected each time want to copy data into. can anyone got ideas how to eradicate this problem ?
    Problem Solver:
  • 12 Answers
First check to see if there is a switch on the USB drive if so switch it. Also you can try this - Start > Run > type ‘regedit’ (without the speachmarks) > Enter
- Single-click on ‘My Computer’ > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDeviceP olicies
*There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK*
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
The last solution is that the USB device is bad and you will have to replace it.
Posted on Dec 05, 2008
I have A-data my flash 8GB usb which write is protected please tell how i can Fix it ,,when i try to format the usb it say windows was unable to complete to format
The problem isn't with write protection. The file system has become corrupt and unreadable, or at least a section of it. If you can't reformat it then it's likely dying or dead. At least you should be able to recover some of your data however...
Go here and get a FREE copy of USB Flash Drive Data Recovery Software:
http://www.easeus.com/resource/drive/usb-flash-drive.htm
May 15, 2012 | Electronics - Others
My Transcend JFv30/1GB flash drive was corrupting files..sometimes i can't copy or delete files cause it was write-protected...how can i fix it???
Your best bet is to reformat your drive. Go to your My Computer and select the drive. Right-click on the drive and select Format. you can then reformat the drive. Be warned this does delete all of the Data on the drive.
Mar 03, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Last year I copied photos onto my 1GB PNY Attache Flash Drive. I've viewed the photos several times, so I'm sure the photos copied correctly. Now when I put in the flash drive, my computer says 0 files....
Hi
Please follow these steps
1. I think its not a problem with flash drive.
2. There should be virus in your computer.
3. Please install anti virus or if it is already there update it.
4. I think that virus is deleting your files in the flash drive.
Jul 30, 2010 | PNY Attach? 1GB USB 2.0 Flash Drives...
Showing write protection problem
move the small jack present on the side of your memory card,it is for write protection enble, disable.
Mar 16, 2010 | Kingston 1GB Secure Digital Memory Card
I cant format my 1gb usb when i was formatting it it always says that it is write protected and it wont be format
Does this USB flash drive have a small slide switch on the edge of the drive to write protect the data on the drive?
If so move the switch to the read/write position.
Dec 11, 2009 | Computers & Internet
Disk is write protected
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Jun 27, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
My 1gb flash disk tells me its write protected
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 19, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
Dec 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Backup copying seems at a standstill
Okay Ive got the solution for you you. You need to reformatt the harddrive initially and then when you copy your 10Gb of data you need to split it up and copy it in smaller portions, because what is causing you problems is damaged or corrupted data files that you are trying to move and the system cannot copy them. by copying your files in smaller bundles lets say 1gb or 2gbs at a time you should be able to isolate the problematic files. this method also helps to avoid congestion in your buffers and processor. thanks
May 26, 2008 | G-Technology Computers & Internet
Computers & Internet Logo
David Payne
David Payne
