Question about Nintendo Game Boy Color Console
Game cartridge I recently purchased a used ZeldaDX cartridge, and when I turned it on the tittle screen comes on fine, but when I press start to continue, the screen glitches, turns white, and the sound goes to one solid tone. I took the case apart and polished the connectors w/ toothpaste then alchohol, let it dry and tried again. Same thing. So I damped a q-tip w/ alcohol and cleaned the handheld connectors, same thing. Next I cleaned my GBA and it still glitched. Maybe it was corrupted by a Gameshark?
    Problem Solver:
  • 14 Answers
Re: game cartridge
Gameshark has been known to corrupt both saved games and games themselves. Did someone at the store tell you to clean it with toothpaste and alcohol? I'm thinking what happened is the electronics were damaged due to either the toothpaste, the alcohol or both. Nintendo recommends cleaning your cartridges with a dry cloth to get the dust out. If it had some sort of liquid spilled on it before, which it sounds like it may have such as coca cola or the like, then it would have been damaged before you bought it.
Posted on May 01, 2007
    Problem Solver:
  • 7 Answers
Re: game cartridge
Easy solution, get a DS no serriosly why the heck do you still have this thing? oh well, ether you game is shot or its not inserted correctly. Get a DS
Posted on Jun 13, 2007
0 characters
3 Points
Top and bottom screens are white
Sorry for the delay. If the dsi won't turn off when you first get the white screens, hold the power button for 8 seconds. The unit should go off. Take the game cartridge out of the unit and inside that cartridge slot, is a reset button. Using a toothpick or something, press it. Turn the unit back on and it should be fine. Hope this helps :D
Nov 13, 2011 | Nintendo Dsi Pink Console
Ds keeps coming up with "An error has occured. PRess and hold the POWER button to turn the system off" when I try to play Super Mario game. All other games are fine.
Since it is only causing a problem for this game, the problem is likely with the game and not with the DS itself.
Is this a newly purchased game? Sometimes black market games will show this problem.
If it is not new, then check the bottom parts of the game cartridge to see if there is some damage or dirt. These can make the game unreadable. If it's only fingerprints, you may be able to clean it, but otherwise you'll have to purchase a new cartridge.
Best of luck.
Jul 21, 2010 | Nintendo DSi Black Console
Why my sega gen mobile wont turn on?
The Sega Genesis 2 Console requires Game Cartridges. The console is only a processor and has no pre-loaded games.
Apr 30, 2010 | Sega Genesis 2 Console
Pes 2009 stopped loading
Delete The Update File From Game Data Utility And Redownload It Works Fine After. But Online Mode Does Not Work Anymore...
More And More Game Now Days Need All This Updatein Hardly Any Of It Works All I Ask For Is Workin Game's.. You Pay £39.99 For Wot Broken Games?
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
N64 Blinking on and off
It seems like an issue with the cartridge slot (as in there's a bad connection somewhere, causing the connection with the cart to be lost, then restored, then lost... etc). Try giving it a good blast with a can of compressed air or possibly go over it with a Q-tip soaked in glass cleaner or 50% isopropyl alcohol.
It may also be an issue with the power cable. I have a similar problem with my Genesis resetting and turning off. It turned out to be caused by a faulty, loose, power cable. Try finding another power cable for your N64 and see if it makes adifference.
Sep 26, 2008 | Nintendo 64 Console
Games not loading
try putting in a UMD that what i did for mine games works find if that dont work go into recovery mode turn off the psp system and turn it back on and hold the r button and go to configuration then go to use no umd and enable it then exit then the games should work just find.
May 26, 2008 | Sony PlayStation Portable (PSP) Console
N64 Console
try using the cables instead of RFS's
Apr 01, 2008 | Nintendo 64 Console
Nintendo Game Boy Color Console Logo
89 people viewed this question
Top Nintendo Video Game Consoles Experts
Troy Gorman
Troy Gorman
Paul Layton
Level 1 Expert
Are you a Nintendo Video Game Console Expert? Answer questions, earn points and help others
