Question about GE Advantium 120 Convection/Microwave Oven
Advantium 120 oven quit working- only 3 yrs old!
The convection oven recently began shutting off on it's own, but you could re-start it to finish heating up food. Within the week, it finally quit working all together. Breaker is not tripped and plug outlet is fine; check on other outlets.
  • Anonymous Dec 08, 2008
    OK, I've pulled the hidden manual and narrowed down a problem. I do not care about destroying this oven b/c it's out of warranty anyway, so after taking oven semi-apart, I found he upper thermostat TCO is scorched/melted on where the 2 red wires plug into tco. Looks like I can order a new thermostat on line and fix it myself, but why did this happen? Would this also cause any fuses to blow? Thanx.
  • mwis57 May 21, 2009
    My oven just quit after 3 yrs. and found the wiring harness melted together .Waiting on a service tech to re wire the unit. Whats with putting on a new harness, are the replcement parts not up to par?
  • GE Master
  • 9,098 Answers
You probably have a failed thermistor / temperature sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you need to remove it from the wall, y
ou can download GE installation instructions here.
Posted on Dec 08, 2008
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium won't shut off
The problem is the microprocessor control board, professional should verify.
Mar 11, 2012 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 model # SCA1001HSS03 has died and working. The circuit breakers is fine. The dedicated electrical line is working fine. There are no lights, no sign of life. The oven was working and at the...
Many microwave ovens have an internal fuse , but I was recently told by a dealer that any unit costing under 200.00 was not worth fixing .my fuse cost 3.15 from local home improvement store
Oct 19, 2017 | GE Advantium 120 Convection/Microwave Oven
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
165 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
