I have a Carrier weathermaker 8000 furnace that has a loose Inducer Motor connector at the board. My furnace would fire when I wiggled the connector, but know that won't work. Is it possible for me to remove the panel, to see if something is broken or disconnected?
  • 85 Answers
Go ahead, just turn off power to breaker box first, or you'll be cursing for at least 10 minutes...
Posted on Dec 04, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Will not ignite. LED Code 31
Could well be the inducer motor Google carrier 31fault code there are 3 video's on this on u tube
Jan 15, 2018 | Carrier Weathermaker 8000 Gas Furnace 125k...
Furnace gas valve is not opening
YOUR FURNACE IS IN LOCKOUT MODE DUE TO A SAFETY FEATURE OF UNIT. USUALLY THE HIGH LIMIT HAS BEEN TRIPPED, OR YOU PRESSURE SWITCH FROM DRAFT INDUCER MOTOR FAULTY OR PLUGGED. IT WILL CONTINUE LOCKOUT MODE UNTIL THIS IS FIXED.
Dec 23, 2012 | Carrier Weathermaker 8000 Gas Furnace 125k...
Where does the 3 prong inducer plug into? Carrier Weathermaker Model 58SXAO80-GG Serial 1490A02296
Hi, it would either plug into the circuit board/control board, or have a connector of the same, either male or female it would plug directly into. This is a 120 volt inducer motor. Look for the other end of the plastic plug.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Sep 29, 2010 | Heating & Cooling
I have a Carrier Weathermaker 8000 VS furnace that intermittently has frozen up (the inducer blower stops spinning). Do I need to replace the blower or is there something else that can be done? What is the...
If you can get to the shaft of the motor, oil it using electric motor oil. If the motor spins freely, you just may need to replace the start capacitor, however if it is binding; you will need to replace the inducer as an assembly.
Jan 18, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace won't work because of a loose Inducer Motor Connector
Cut power to the system at the main disconnect.
Turn the gas off at the unit.
remove the panel, andsee if the stakon conection is intact. Chances are its just a loose connection from your description.
If the problem is not obviose, let us know what you did or did not find.
Dec 04, 2008 | Heating & Cooling
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
