Question about Vulcan VC44GD Gas Double Oven
Ignitor problem? I have an oven that seems to be emitting gas,I can hear the ignitor start, but the oven does not light. Any suggestions?
  • Anonymous Nov 11, 2008
    we have the same proplem with are vulcan gas convection oven the ignitor sparks but the flame does not light i cleaned the flame detector probe and also changed burners and probes from top to bottom oven to see if probe was bad and top oven does the same thing it still well not light it only sparks but will not light please help thanks its a vulcan gas convection oven model VC4GD-its a stackable unit
  • 640 Answers
If you remove the 2 screws on the right and left bottom plate and open the door and youll see 2 screws that panel will come off turn the oven on and you should see 2 burners on both sides and they should ignite.if they do and go right out you could have 2 problems.when the burners light they hit a probe called a flame sense.this probe plugs into a heat board and if the board doesnt sense the flame you will get a red no ignition light.clean the probes that sit right on the burners with sandpaper and see what happens,if that doesnt work if the unit has pilots clean the pilot orfice and if that doesnt work the heat board may be bad.how old is the unit?
Posted on Aug 01, 2007
On my GAS stove and broiler work fine but my OVEN does not light. I do not hear the pilot light or spell any gas. Where or how can I check
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 29, 2011 | Frigidaire Ovens
I have a Kenmore gas range and the oven is not working. I do not hear any click (igniter) and I do not smell gas when I turn it on. The burners on top work fine. Any suggestions
heatman101
Dec 27, 2010 | Kenmore Ovens
Used oven yesterday..... worked perfect. Went to turn in on today.... ignitor glows, but oven burner will not light. Any suggestions?
ignitor loose capacity... in order for gas valve to open ignition level have to be not less then 3 A. if it less then ignitor will glows but gas valve want open... So you should replace ignitor, but if you have tools (electric meeter) check if it's less then 3A, you can check one of the two wire on ignitor...
appliancesrepairla.com
Jun 26, 2010 | Kenmore Ovens
My gas oven makes a noise
This is because the ignitor is starting to fail. The ignitor is probally just barely reaching the correct amp draw and soon will not light at all. For a free video on performing an amp draw test go to www.appliancehelponline.com/servicemanual.html this will walk you thru the testing procedure.
Mar 29, 2010 | Kenmore Ovens
Gas stove the burners are working but the oven is
Hi, The ignitor in the oven does not spark. It glows and has to pull enough amps to open the safety gas valve. The most common issue with these ovens is the ignitor. It can glow red but not be strong enough to open the valve. Remove the bottom panel in the oven and you can see the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Ovens
Wall oven will not light
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Mar 28, 2009 | Maytag 24" Built-In Single Electric Wall...
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Oven will not light
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Vulcan VC44GD Gas Double Oven Logo
550 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
